HUNTER 340 Yanmar 3GM Engine Mounts... OUCH!
Oct 26, 2024
68
Hunter 340 Morton Bay
Hi Folks,
Need to replace all four engine mounts on my 3GM Yanmar as they've gone soft and engine rattly and vibrating lots.
OUCH!!! ... was shocked and amazed at price of these for a little lo-tech block of rubber and metal.
Around $2000 AUS here down under. And that doesn't include labour for fitting and shaft alignment.
So I started snooping around the Net... as you do, and found these US based options which look pretty good. And sub 1K (AUS$) for a full set. They're stainless and urethane which makes sense.
Does anyone have any experience with these (pic attached) or.... any other suggestions of recommendations?
Many thanks in advance - Mark Mac QLD AUSTRAYA
Nov 6, 2006
10,195
Folks have given good reviews of these mounts:
arf145
Nov 4, 2010
498
Beneteau 331 Deale, MD
I have no experience with those mounts, but they look fine, with what looks like good damping. What you don't want are extremely rigid type after market mounts that transmit a ton of vibration to the boat.
Oct 26, 2024
68
WOW! Seems unanimous. Ellebogen mounts seem the go to.
Thanks to all for your informed input cheers.
I also noticed on their website they have some cool tricks for replacing without going to great lengths to 'jack' the motor. It's a video if ur curious. Shall order a set and 'rattle no more'
Thanks again. Love this group!
I just read through the data sheet. The metal on the Ellebogen mounts is galvanized steel painted over for additional protection ... NOT stainless. The spec sheet claims it has the same resistance to corrosion as SS.
Might be true but if you knick the paint... you will start to have problems later on.
Oct 26, 2024
68
Yes mate I did notice that.
Cuppla things: Pretty sure the original mounts are not SS. For around the same price the SS option certainly looks attractive. My only concern is that as Tom (arf145) pointed out above, the insert on aftermarket could cause heavy vibration issues if its a 'one size fits all' rubber compound. My 3GM is comparatively light I would have thought. I'm not sure if the urethane insert in the SS variant, which the manufacturer promotes as a positive, might be too 'hard'?
