Lewmar lens replacement
Apr 26, 2021
13
Hunter 306 CVDM
I have a Hunter 306 2003 and i need to change my 13x13' lens on one of my rooftop hatchs (put my foot on it!). Its dificult to find the right lens: is the MK I and MK II lens be interchangeable? Were could i find the lens? Thnaks.
Hatchmasters.com is/was the place to go for Lewmar hatch repairs. However, they are temporarily closed.
A good plastics shop can make one for you from the original. Tap Plastics is one source online.
  • Helpful
Likes: rgranger
dLj
Mar 23, 2017
5,087
Is the frame in good shape? Do you just need the lens? Got pictures of the lens?
I've simply built all the lenses I've needed on most of my boats over the years. I don't find it difficult to do although it is fussy, depending upon attachments. I usually just buy the lens material and make the shape needed.
dj
dLj
Mar 23, 2017
5,087
How does that handle attach to the lens? It's not clear from the pictures.
dj
Apr 26, 2021
13
Hunter 306 CVDM
It’s glued on the lens. There is no screen throw the lens (so MK1) but there is no roll pin hole on the frame (so MK2). It looks like the lens dimensions of The MK1 and MK2 are the same.
Sep 24, 2018
4,507
Catalina 30 MKIII Chicago
On many Lewmar hatches (your's looks like mine), the gasket is sandwiched between the frame and lens. Now would be a good time to replace the gasket as well.
Does anyone know the approximate tint on these hatches so that new material can be acquired?
Jun 17, 2022
539
Hunter 380 Comox BC
Oops! I did that as well.... These lenses are easy to replace, they come with the rubber seal and the latch glued on. The frame seperates in two. Check out defender.com
There is a part no inscribed on the inside of the lens, lift the rubber seal a bit and you'll find it. Likely Mk2, as they were delivered around 2000-2001.
Last I checked, we could not get the acrylic that lewmar uses in North America. The other challenge, is gluing on the latch. The edges would also have to be precicely routed. It would be a lot of work and you'd have to figure a way to get the old latch off the glass and what adhesive can be used to install on the new hatch.
They are relatively affordable, just buy the part from Lewmar via your local dealer or defender.ca (owned by a canadian company FortNine / NovaCap)
604
Hunter 306 Pasadena MD
I have the same boat (H306, which isn't very relevant, since these hatches are everywhere). But I will comment that my handle came off that same hatch, and I was able to glue it back on with some cheap hardware store "epoxy for plastics". I didn't think it would hold, but it's been maybe 3 years now, and it has held perfectly despite the sun beating down on that glue through the hatch lens.
Likes: marcham
