Hi Folks,
H340 standard 'loose footed' mainsail outhaul system is a bit of an inefficient mess.
Not sure what the previous owner had going on here... but it simply doesn't work how it should. Hoping someone can shed some light.
I'm 'guessing' there's an in boom purchase set up which then comes to the gooseneck through what looks like an exit sheave/jammer clutch under the boom. (See pics)
It looks to me like the outhaul 'tail' has gone back up inside and now faces the wrong way. If I can screwdriver 'fiddle' the tail forward over the sheave and through the jammer... is this how it's meant to work?
I'd rather not remove the boom end if I can avoid it.
Cheers and thanks in advance for any tips and tricks - Mark Mac
