Old ST60 with new transducer: wind speed is reading quite high.
Call me a heretic but I think as someone sailing apparent WS is what I care about. What else matters?
I understand to rate your performance against polars you have to work in TWS. But analogous to true North vs Magnetic North, one is actually what you are seeing. I don't know why there is such an effort to determine TWS when at the helm you are sailing in AWS.
In the sailing area I'm used to current is paramount. So it's really helpful to know STW vs SOG. The difference between SOG and STW is current and a few other phenomenon. Nevertheless we are sailing in the conditions that exist at the moment. That is what is great about it.
I guess I’ll call you a heretic:poke:;). I can think of a few reasons you’d want to know the wind speed at all: (1) measure your performance against expectations; (2) know what to expect the conditions to be if you change course; (3) know when to reef; (4) bragging about the gale you were in. For all of those except maybe (3) TWS is what matters. For (1) polars are universally in TWS, and even if you don’t have polars if your sails are badly trimmed going upwind and you’re going slow, you could just think “that’s because the wind is so slow”, but the AWS is just low because you’re not going forward as fast as you should. You need a boat speed independent way of measuring the conditions to know how fast you should go. For (2) If you’re going upwind and want to estimate how fast you’ll go on a run, to know how long it’ll take to go home, you’ll want to know that you’ll be running in 8 knots of true wind, not the 12 knots of wind that you see apparent going to windward. For (3) I think some multihulls might have sail limits based on apparent wind, but otherwise most reefing is done by true wind or feel. For (4) bragging about apparent wind speed if you’re on a fast spinnaker run wind wouldn’t be nearly as impressive as using true wind speed, and bragging about apparent wind speed going upwind would be a little disingenuous.
