Is h260 forestay used without modification in jib furlers, usually?
Oct 8, 2023
79
Hunter 260 Kemah
Forestay in jib furler broke up top. Arg. Generally, generally, is h260 forestay used without modification in jib furlers, usually? And no need to shorten the stay for furler? Can one slide stay thru, or must use bare cable then put on T-ball terminals?? Sorry for such basic questions, I am new to fixing rigging. Does top of jib furler usually not have any rotating part, the "foil" the sail wraps around just rotates around the stay wire , which is cool if it's that simple a system up top?? I know so little about jib furlers they just seem to magically work they are great. - D
1,385
No modification required for forestry but must cut the foil to size. To put the forstay through, I used fish tape then pulled a line throuh then attached the firstly and pulled through. My H25.5 was trainable, so I dropped the mast. Is it possible to drop the mast on H26 to drop the mast?
@Davenport
This SBO site is owned by former Hunter employees and they have the build list. They can make you a new forestay that is the correct length. Call the store and tell them what you need.
  • Helpful
walt
Jun 1, 2007
3,542
The forestay gets bent back and forth with jib sail pressure. Add on a furler sleeve and it tends to concentrate the bending force at the ends of the stay and if I see the pictures right, your wire break at the top is at where stays fray because of inadequate rigging toggle.
When you fix things, you should make sure to have good all axis toggles at both ends of the stay. The furler bottom likely already has a pretty good toggle but make sure you have a good toggle at the top. To see what the toggle is, google something like "sailboat rigging toggles"
Oct 8, 2023
79
Hunter 260 Kemah
the online hunter store has a h260 forestay for $170, I just can't tell if that will work inside a roller furler without changes needed? I think so, the furler spins around it, I think
Furlers come in different configurations. Some use the forestay like Harken. Some come with their own internal wire/rope like CDI.
Which brand do you have?
The answer to the query you posted will be revealed in the instructions for assembly.
Joe
Jun 1, 2004
8,238
Determine the kind of furler you have. Then look for installation manual online. During this process you should learn the difference between various makes of furling units. The installation manual will cover any modifications needed to the forestay.
Mar 2, 2019
616
Oday 25 Milwaukee
Jssailem ,The CDI furlers do not come with their own wire luff . Dave ,why would he need to cut his furler ?
Davenport . order the forestay , and you will be back on the water in an hour .
3,579
I seem to remember many guys added tangs to the bottom of the forestay to keep the drum from rubbing on the deck. They then ran out of room on the turnbuckle, so the forestay was never adjusted quite right.
This is all from memory and may apply to only the 26 not the 260.
If there are tangs on the bottom of your forestay you may want a slightly shorter one than the specs call for.
-na -NA Anywhere USA
@Rick Webb
Although the 26 and 260 are the same hulls there were some changes. The drum on the 26 used tangs secured to the anchor locker while the 260 drum is secured directly to.a designated forestay Deck.chain plate
  • Helpful
Likes: JamesG161
