I have an 1980 hunter 33 which does not have any clutches, organizers or winches mounted on the cabin top. I'd like to bring my main halyard and boom vang to the cockpit to ease solo sailing (maybe I should bring more?). I have two questions for you more experienced cherubini hunter owners:
1. It appears there is a liner with an airgap (or is it foam?) between the cabin roof and the deck - I assume I can't drill all the way down from the deck to mount clutches etc since the bolts would pull through the liner.
2. There are some mounting plates on the desk - I assume that is what they are. I attached a photo. Can I screw an organizer for example onto one of these and expect it to hold? Do I need to drill through them instead, and if so are the solid all the way to the cabin roof?
A friend suggested adding a rectangle of G10 board fixed with 5200 epoxy to the deck and screwing the clutches etc onto the G10 board. Do you think that will hold? Would it hold a winch?
I appreciate any advice or experience you want to share!
thanks
Damian
thanks
Damian
