In search of a rudder transom mount for a Point Jude 16
Aug 21, 2025
13
Point Jude 16 lansing
Hello all, I recently purchased a 1990 Point Jude 16 at an estate auction. It’s in great shape however when I got home and checked it out it is missing the rudder transom mount. I have the rudder and tiller but not the mount.
Any ideas where I can find a replacement or even the plans to make a new one?
I’ve attached a picture of my boat and a picture of the missing part I copied from the internet.
Thanks for all the help!
Do a search for Gudgeons and pintles. That’s the proper name for the part you’re searching for. Sailboat owners, (This website) sells them but so do lots of other places.
Sep 24, 2018
3,519
Catalina 30 MKIII Chicago
While they may be somewhat universal, if you can find a logo or writing on the hardware, it might help you find a matching set
dLj
Mar 23, 2017
4,455
What you haven't shown us are the pintles on your current rudder. You will need to know the pin offset, diameter, and length to find appropriate gudgeons.
On your boat, it would be fairly simple to fabricate gudgeons that would function well. The attached photo shows that the top gudgeon and bottom gudgeon are separate pieces. Each could be made from sheet metal. If you would like more info just ask...
dj
Aug 21, 2025
13
I’m sorry but apparently I wasn’t clear about what I need - I need the WOOD part that the tiller mounts to and the rudder blade hangs from. It’s the part with pintles that hang on the transom. Here is a picture of what I need - I copied it from the internet.
Joe
Jun 1, 2004
8,224
Are you also missing the upper wooden part of the rudder that attaches it to the boat? How about the hinge bracket for the tiller? If it's just the pintles and gudgeons, those are usually generic and a few measurements are all you need to find them in a good rigging hardware catalogue such as Rigging Only or Rig-Rite Inc. - Masts, Booms, Spars, Rigging, and Hardware for Sailboats.
Oops, just saw your reply. I'm afraid you're looking at a jr. hi. woodshop project... if you can't find an owner's association or other small sailboat resource. That's a pretty cool looking skiff. I did a quick search and found info like history, specs, etc. I really hope you get that little sweatheart on the water... besides being extremely seaworthy (according to comments I read) it should turn a few heads in the parking lot. Designed in 1946 by Edson I. Schock (hmm any relation to WD Schock?, notable builder designer still in business)
Anyway, good luck. a good quality hardwood plank, a little skill with a router and a reasonable quantity of epoxy or helmsman spar urethane will put you on the water.
dLj
Mar 23, 2017
4,455
Ah - sorry - so you do have both pintals and gudgeons? Do you also have the metal straps that would hold that piece on?
If you have all the metal bits, then it would be a fairly simple task of measuring the width of wood needed to fit into the top - basically the same width as your tiller.
You can pretty much take that image and make a scale drawing. Then make the missing wood piece. I highly doubt you are going to find that available. It will have to be fabricated. Print out that photo - take your dimensions from the parts on your boat and you will have a scale based specifically on your boat. Then use those measurements to scale out what you'd need for your wood part. Does this make sense?
dj
May 12, 2025
51
Macgregor 22 Silverton OR
It would probably be best to take another picture of your boat stern while it's parked on the trailer showing what rudder hardware you have on it now if any. Congratulations on purchasing a small sailboat and a new language.
Sep 24, 2018
3,519
You'll most likely have to make new wooden pieces but heres the Point Jude Class Association's info:
Point Jude 15 Class Assn.
401-789-0424
c/o South County Marine
20 Fairgrounds Rd. #8
West Kingston, RI 02892
There's a ton of good info in this thread
13
dj
The gudgeons are on the boat but no I don’t have the pintles because I don’t have the wood part they mount to. Thanks!
Aug 21, 2025
13
Thanks everyone for helping a newbie! Here is what I have and my dad is an accomplished wood worker but he needs a pattern.
What is the hole in the top of the rudder blade for? There are two - a horizontal thumb size hole and then a vertical pencil size hole. I’m guessing something to do with “kick-up”?
dLj
Mar 23, 2017
4,455
I believe from what I can see, this is what the different parts of your existing rudder are.
dj
dLj
Mar 23, 2017
4,455
Tale the image yo have of what this wood piece should be and print it out. Then use it as a diagram to design the top part. I've labeled here a couple critical points.
dj
dLj
Mar 23, 2017
4,455
Let us know if this helps and if you have more questions.
dj
dLj
Mar 23, 2017
4,455
Thank you! Can you explain the hold down line - I have the owners manual that briefly describes it but I don’t understand without pictures.
The rudder is wood so will float. The pivot point is there so you can beach the boat by pulling up the dagger board and the rudder. Also the rudder should pivot up if you hit something so it doesn't break.
Sometimes the hold down line is a Bungie cord, sometimes a line. There may be some sort of attachment point on the aft part of your rudder to attach a line to pull the rudder up but I can't see from your pictures if that's the case on the boat. I also can't see from the pictures where the hold down line runs exactly on this set-up. But you can make it in numerous ways. You need a hold down line so the rudder stays down in position while sailing.
dj
Joe
Jun 1, 2004
8,224
Would you mind sharing what the owner's manual says, that could help a lot. Please, don't hold anything back. You may be overestimating our expertise. While you're at it, if you have a profile picture of the rudder blade, one that actually shows the shape of the two vertical edges. Remember that rudders are "foils" like airplane wings. It is common for the leading edge to be rounder than the trailing edge, just like your centerboard, or sails, etc. thankyou
Aug 21, 2025
13
dj
Here are the holes - a larger horizontal one and a small vertical one leading to bigger hole.
13
From the manual:
