New 216 owner with missing parts
Jul 27, 2025
4
Hunter 216 Lake Aylmer
Hello, first time poster here, happy to join the forum. We bought a 2008 216 to use at our lake house on lake Aylmer, Canada. The boat is in decent shape and the sails are like new, but the boat is missing several parts for which I would need help with the specs. More specifically:
- Diameter and length of the following clevis pins:
- Gooseneck
- Upper and lower pins on Harken furler spool
- Mast step (is it even a clevis pin or is it a bolt or something else?)
- Mast stop (make and model ideally or is it flat or round? size? etc.)
- Boom vang blocks (make and model)
- Tiller extension make and model
Thanks in advance. I'm sure there will be more question.
(tried to attach a picture but getting "Oops we ran into a problem").
Jul 27, 2025
4
Thank you. I had already browsed that content but did not find the information I'm loking for.
Aug 17, 2013
1,062
Pearson P30 202 Ottawa/Gatineau
Lake Aylmer as in Aylmer Qc?
If so, look at the chandlery in Ottawa
If you have access to a caliper you can measure the size you need.
Tiller extension, use whatever you like, same for the blocks, see what you want and need
Jul 27, 2025
4
No, about 450km east of there in Stratford QC. No chandleries around here, I'll need to order online.
