My shower sump is no longer working. There is no suction. I've cleaned the filter. The pump makes a noise, yet it won't drain the shower sump or the refrigerator when the Y valve is set to that position. On my 2002 Catalina 310, the shower sump hose runs from the sump to a Y-valve under the sink, which is shared with the refrigerator drain hose, and then to a seacock under the sink. How would I access the drain hose from the shower sump to the y valve if I want to replace it? It is an original hose.
