How to access shower sump hose on Catalina 310 for replacement?
Apr 6, 2013
166
Catalina 310 Annapolis
My shower sump is no longer working. There is no suction. I've cleaned the filter. The pump makes a noise, yet it won't drain the shower sump or the refrigerator when the Y valve is set to that position. On my 2002 Catalina 310, the shower sump hose runs from the sump to a Y-valve under the sink, which is shared with the refrigerator drain hose, and then to a seacock under the sink. How would I access the drain hose from the shower sump to the y valve if I want to replace it? It is an original hose.
DaveJ
Apr 2, 2013
528
I have the same setup, your hose is probably ok. If the fridge drain also doesn’t work, then I suspect the gasket on the filter is the issue. That’s what happened with me. I went to the local hardware store, found a similar rubber ring and trimmed a bit off so it would fit. Has worked for a couple of years now…..
Good luck.
Apr 6, 2013
166
Good luck.
Thanks! I will give that a shot.
JRT
Feb 14, 2017
2,059
So where is the filter? This is a new one for me and I lost suction too
DaveJ
Apr 2, 2013
528
Going to the boat in a couple of hours, will take pics.
my filter is under the sink, beside the y-valve. It is clear with a metal screen in it.
DaveJ
Apr 2, 2013
528
Pictures…. The filter is the 1st pic. There is a gasket available, for a couple of $$, but with delivery to Canada I didn’t do it. Cheers
john2
Nov 26, 2022
103
Catalina 310 58 Leimuiden
our PO had drilled a hole under the engine in to the bilge. :banghead: i made openings in the floor so i could clean the bilge.
it gives also acces to the shower hose.
Be careful with the holes.
Catalina uses a solid pan insert to stabilize the hull and provide structure for the interior.
Your hole-cutting plan might compromise this pan design.
