I am replacing the vent and hose on my boat and the old vent is just reinforce nylon. Given all of the choices available is this the correct hose for this application?
It would be too easy and too inexpensive, so obviously it won't work on a boat.I am replacing the vent and hose on my boat and the old vent is just reinforce nylon. Given all of the choices available is this the correct hose for this application?
The Trident 148 is pretty stiff and hard to route sometimes, but it makes a good vent and is available in all the common sizes. It's what I used on my last two boats.I think the only sanitation hose available in smaller sizes is the white Trident 148 and similar from other manufacturers. Although this is not the best hose for waste, it works very well for vents. I used it on my last boat (cruising cat) after clear vinyl failed (the OEM hose failed, and my replacement started to stink soon too) and was quite pleased.
Yes, the nylon reinforced clear vinyl (what I think you were describing) will permeate within a few months. It also kinks too easily, resulting in a blocked vent.
Good luck!
