I am collecting the parts to fly an asymmetric spinnaker with a wire or rope luff from a furler on my Catalina 27. Here is my plan so far: I have a Schaefer single line EC furler, which I will mount on a sprit copied from the Cat 27 tall rig. Plan to use 2 blocks from a crane at masthead: one with a becket attached to the crane, the single attached to the top of the furler. Will run the halyard to the cabin top where I have a winch and cleat. From what I can gather, I will need a lot of tension to furl the sail, but would want to be able to loosen it while flying the sail. I am looking for advice from those who may have used such a set up. I frequently sail by myself. Any better ideas or comments appreciated...Jon Martin in Bellingham
Thanks for all of the comments - I think I am on the right track. I'll forego the 2-1 halyard, and if the luff is not tight enough to get a good furl, I can use the backstay adjuster - should of thought of that first. My plan is to get the sprit designed and installed this year along with the other components, and then have a sail made with a wire luff next winter as my 60th birthday present to myself! Thanks again - Jon
