A while ago I posted a question (http://forums.sbo.sailboatowners.com/showthread.php?t=14860) dealing with rail mounted solar lights. I decided to go with lights from eMarine Solar (http://emarinesolar.com/solar-lights/solar-rail-lights.php) because I'm not too thrilled with having my boat look like a tiki bar and I figured that something built for the marine environment would last a lot longer than the typical garden variety light and would pay for itself in the long haul.
I just received them and was I mistaken! There's nothing about these that are "marine" grade. Here's the letter that I just sent them:
-- Geoff
I just received 4 of your solar rail lights and they're a piece of crap! These things won't last in marine environment for any length of time. Starting from the outside:
How do I get my money back?
So, save your money and don't order this "marine grade" junk. I also attached 2 images showing the construction. Don't you love the one where you can see the circuit board from underneath?- You're using soft-iron (not stainless steel) screws to hold the light dome retaining ring on.
- There's absolutely no attempt made to seal the battery or the electronics from external water sources.
- There are 2 holes (one large, one small) in the retaining ring which would allow large amount of water in from the underside.
-- Geoff
