Well this is going to be a restoration thread.
I picked up my new-2-me Balboa 26 last weekend and I'm just about ready to drop the keel and sandblast it. The keel weighs 1200lbs so I'm a bit intimidated.
Here is what the keel looks like now and I'll post pics along the way. I'll also need to cut away some fiberglass where the PO glassed over the pivot pin (see pic).
Here is what I've done so far...
Today I found an engine hoist for $75 on Craigs List. I'll use that to hold up the keel while I'm working on it.
I also drove to Harbor Freight and as fate would have it they have a 5 gallon sandblast hopper on sale for $38 and they are also running a special on compressors, $178 for a 6 gallon compressor with 125psi ability. I only need 90 psi so this should work. I've never done any sandblasting before so I'm really looking forward to that part of this project. And thanks for the concern... yes I know about siliconosis of the lungs. I have a really good respirator.
The next thing on the list is to build a cradle with wheels to drop the keel into... so I can then pull it out from under the boat and hoist it up with my engine hoist. I'll start posting pics then. I found a pic of someone who has done a similar job on a Catalina 25 and here is the pic of his cradle. I'm going to model mine after this one.
If you have pics of a keel cradle that you have made, I'd love to look them over.
My plan is to finish the job and put the hoist and sandblast equipment back on Craigs list (I'll probably keep the compressor). I'll also try and keep a running total of cost along the way.
By the way... If any of you are considering a Balboa, I'm very impressed with the construction. All of the reviews I found said it was stout... and boy they were not kidding. The hull is thick and there is no give in any of the panels when I push on them. Inside or outside of the boat.
I think that once the keel is resurfaced, I'm going to have a first rate sailboat.
Fair winds,
r
Fair winds,
r
