Slow under power
YVRguy
Jan 10, 2013
479
Hunter 34 Vancouver, BC
My buddy and I just purchased a Hunter 34 and we're sailing it home this weekend. One concern I have is that during sea trials the boat was not very fast under power. We couldn't make much more than 6kts at full power and she seemed to want to cruise at about 5kts. We were with the tide at the time.
Does this seem a bit slow? I also noticed that it almost sounded like the prop was cavitating a bit (it's a 2 blade). The engine is a 24hp Yanmar.
Thanks for any thoughts you have.
Blitz
Jul 10, 2007
709
Seidelmann 34 Atlantic Highlands, NJ
Search "Prop Size ": there is a similiar discussion going on right now under "mid sized boats"
Dec 4, 2003
90
Hunter 356 sandusky ohio
I have a 356 and those are about the same speeds I get. I have a 27 hp. with a 3 blade kiwi prop.
Mar 25, 2010
152
Hunter 34 Rose Haven MD
You may be aware that the hull speed formula is
so for an H34
Hull Speed = 1.34 X √28.25 (28'3")
Hull Speed = 1.34 X 5.32
Hull Speed = 7.12
So consider how clean the hull is ....
Nov 6, 2006
10,098
yep, hull cleanliness and propeller cleanliness (and rudder and keel) Using GPS for a speed reading??
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
All said
All already said clean hull,prop and maybe even the mixing elbo will improve speed,I had a 290 Hunter and in spring with new clean bottom paint clean prop and newly cleaned out mixing elbo helped allow the boat do 6knts so easy,my now 07 H-36 with a Flex o Fold lets me do 6.5 and 7 knts motoring.
It's all about all these things and when my boat came from the dealer I did have a hard time doing 6 knts but changing the prop to a different pitch made motoring so much better.
Nick
YVRguy
Jan 10, 2013
479
so for an H34
Hull Speed = 7.12
Thanks, we just had her out of the water for inspection and her hull is clean. By the sounds of these answers the speed under power is pretty normal so we'll have to rely on the wind to get her to hull speed.
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
Nick
Whats the pitch on your flex o fold is it a 3 blade? Do you know what the equivalent standard 3 Blade cruising prop would be?
Apr 8, 2010
1,606
Frers 33 41426 Westport, CT
Yes, we're using the GPS for speed over the water.
GPS is inaccurate for determining "boat speed" (aka speed through the water), since it does not take into account currents. You need to manually add or subtract any current you are in from your GPS speed to determine "boat speed"
Dec 14, 2003
1,433
FourPoints, I believe your statement is misleading: you do not need to substract or add any current velocity if looking at GPS speed !
Since GPS calculates your SOG (speed over the ground) it does not care whether there is current or wind helping or slowing the boat ! And it is dead accurate ! Boat speed as obtained through any type of in-the-water instrument however (i.e. paddle wheel type or other) has to have current velocity pushing or holding the boat added or substracted only if you want to know distance you will cover. So if you have both type of instruments on board and you're reading 8 knots on the GPS and 6 knots on the speed/log instrument, it means your engine or sails are pushing the boat at 6 knots through the water but with the help of the current you'd really be covering 8 miles in that hour ! If you were against that same current, your in-the-water boat speed would still show 6 knots, but your GPS would only show 4.
YVRguy, if you're looking at your GPS take a look at the chart to find out whether your have any current for or against and of course check the situation of the tide where you are as both the ebb or flow will impact your GPS boat speed. FWIW, my 34 reaches 6.5 on both the GPS and the speed/log instruments when in perfectly calm and still waters at 2650 RPM (Yanmar 27, 3-blade 15 X 11 prop). However, GPS speeds drops down to 4 when traveling up the 2.5 knot current of the St. Lawrence river.
If you want the see the difference, look at the 2 pictures here as I was traveling down the lower St. Lawrence, motoring at 5.34 knots through-the water and 13.8 on the GPS. That section of the river has 8.5 knots of ebb tide current. Obviously you need to time your passage going up or down !
Good luck with the trip and welcome to the 34 family !
1,606
absolutly not true, in the context of determining if the boat is going fast or slow. If someone complains that they are only going 4kts according to the GPS, but they are heading into 1.75kts of current, they are actually sailing the boat at 5.75kts as far as anything relating to sail trim or engine RPM is concerned.
ALL discussions of speed (when discussing through the water speed, not race tatics or course strategy) must only consider "boat speed", aka through the water speed. You don't measure your speed performance under power off GPS, it's measured off the paddle wheel, because hull speed and similar calculations ONLY care about the speed the boat is moving relative to the water. At no point does the speed of the water factor into that discussion.
My point exactly! the OP complained that his GPS was reporting him to be going slower than he expected / wanted. Whenever you are determining the boat performance under sail or power, you don't use GPS speed because it doesn't factor in wind or current (you most certainly should use GPS speeds for any navigation purpose because that's what the boat is doing relative to the chart).
While at the same time being dead irrlevant without also knowing what the current is doing under the hull.
EXACTLY! if you take the 2nd example you used, and then the skipper complains they are going too slow because they are only seeing 4kts on the GPS, it doesn't mean they are sailing the boat any better or worse, or the engine is pushing the boat any different, the boat is still moving at 6kts in anything that matters when discussing performance, all the while the GPS only shows 4kts.
If the OP was asking about navigation advice then we would be advising him to use the GPS reported speed not the paddle wheel, because the paddle wheel speed doesn't take into account current to show you true speed over ground.
after argueing against my point, you make the same argument as me? I'm begining to think you actually do understand this, you just didn't read my post very clear before responding.
YVRguy
Jan 10, 2013
479
Thanks for the advice and warm welcome!
Dec 14, 2003
1,433
I re-read the entire thread and must admit I had missed YVRguy post about his looking at GPS speed only in trying to evaluate boat performance, and overlooked the quote about it on your post.
The whole purpose of my post was to cover for YVRguy's sake the difference between the Speed-over-Ground (SoG) and Speed-over-the-Water (SoW) !
FourPoints, you better believe in a lifetime of sailing tidal waters with 16 feet tides and ebb or flow tidal current velocities above 8 knots at times, I indeed understand precisely the concepts of boat speed and GPS speed. ). If not I would be in serious problems !!!
I totally agree with you about current velocity addition or delation in regards to pure boat performance. And consequently I agree that my statement was not true, as you say "in the context of determining if the boat is going fast or slow.''
I do agree also that SoW and SoG are very much inter-related as SoW does influence SoG every inch of the way, for or against. I do know what my boat can do performance wise and other than for evaluating boat performance while underway with SoW readings, when cruising, the GPS provides SoG, real-time instant info as to the progress I am making towards my destination (all conditions being equal obviously). And I don't have to know precisely what the current is doing because the GPS disregards it ! Of course, it saves me from working the old D= S x T formula because it does it for me.
May the winds and currents always be favorable !
Apr 8, 2010
1,606
Apology Accepted :D
YVRguy
Jan 10, 2013
479
As a postcript, I sailed her home yesterday and we had the tide against us as we sailed under the Lions Gate (First Narrows) bridge. GPS indicated only 3kts SOG at almost full power but the old school knot meter was almost pegged! I can see I'll be timing my departures and returns carefully or I'll chew up too much valuable sailing time fighting current.
Dec 14, 2003
1,433
Congrats on your successful "passage" ! :dance: Glad everything went OK ! Good luck with future trips and have fun with your 34. I've had mine for 13 years and still can't find anything that I'd like more. But then again in that respect money is definitely an object ! :D And yes, when sailing tidal waters timing is definitely the name of the game for safe and fun trips.
Nov 6, 2006
10,098
This second Claude seconds that statement.. I have had mine since '91..21 years.. Still very happy with her..
Oct 14, 2005
2,191
YVR...
Great boat; great forum. Ask questions--one of us may have the answer. :dance:
Boat speed through the water versus GPS sounds normal--I have the same power/prop configuration.
Welcome aboard!
Mar 9, 2013
20
Beneteau 411 Staten Island
I've bad mine for 17 years. Love her... I have Westerbeke 21. She'll cruise about 6kts in slack water under power
