Grounding Dynaplate
CYQK
Sep 11, 2009
610
beneteau first 42 kenora
Looking at installing a dynaplate
One that came up was the Guest 4012 12x3x1/2 is this one good? Too big/too small?
Best place to purchase?
Seems to be a must on my project
Thanks
Gary
Jun 6, 2006
6,990
gimmick, all you need is a plate or strut or nut on a wire in contact with the water, preferably going through the water surface to allow the antenna to be grounded. The amount of surface is not that important once you get the RF to the water. It spreads out along the surface so as long as the ground path can carry RF it will work. A thin wire will not work BTW as RF travels along the surface of the conductor not through it. Think braided grounding strap hanging in the water.
I use a mobile stick with base loading ($14 at our ham shack) and a grounding strap 1" wide connected to the grounded end with a large nut to keep it in the water. mount it low as possible to keep the ground strap length out of the water as short as possible.
7,744
Alden 50 Sarasota, Florida
Thanks
Gary
Is it intended as an electrical ground or as a counterpoise for RF?
11,772
This would be for electrical earthing
Earthing for SSB or just ships DC/AC grounding? Engine is fine, unless you have an isolated sail drive leg like a Volvo..
CYQK
Sep 11, 2009
610
Mainsail
Yeah I know the engine will work through the shaft but I was wanting something better
This is for AC/DC grounding
Maybe later for SSB
Is this overkill?
Thanks again
Gary
