I've a Selden Furlex 100S that losses all its lower ball bearings when I raise the headsail. Apparently, the whole drum unit gets lifted off the Ball Bearing Sockets as the sail goes up. The Ball Bearing Tube is still secured to the bearing socket, hence this suggest the upper part of the bearing tube is NOT secured to the drum assembly. Tried as I might, I could not figure out how the drum could be open so that I could tighten the drum to the bearing tube. I wrote to Selden but as I await their reply, I wonder if forumers here have done this before and could offer some help or advise. Appreciated.
