I'm planning to install a 10gal internal fuel tank to replace the 3 gal portable tank that was original to the boat (the original tank finally rusted through at a seam). At the same time I do this, I would like to add an electric fuel pump to prime the carburator instead having to use the manual primer ball every time. Once the tank location is moved, reaching a primer ball will not be as easy. I would like to power the pump from the ignition key choke switch, so choking the engine also activates the elec fuel pump.
I found this fuel pump, which seems like it would work. I contacted the manufacturer and they have indicated that no fuel will flow in either direction through the pump when it is turned off (awaiting confirmation on this now). My thought is to hook up the system like this:
This will allow the elec pump to run for a few seconds to pressureize and prime the fuel system pre engine starting and then be turned off. Once the engine is running the fuel will be drawn through the manual primer ball like normal, with no abnormal restriction in flow. The retention of the manual primer ball also allows, as a backup, the manual priming of the fuel system in the event the elec pump fails.
What I'm looking for is any thoughts or concerns with this type of setup, or altenative suggestions.
