Loctite won't isolate the thinnest area of the zinc, which is where the screw is.Loctite on the screw threads?
The point was, to make sure the screw didn't fall out and lose the zincLoctite won't isolate the thinnest area of the zinc, which is where the screw is.
Does it need to be on the part of the shaft coming outside of the boat (behind the prop)? Will it work if you just installed it inside?Beneteau prop zincs are too small to last long. In my neck of the woods, they typically last only a couple of months. Consider adding a limited clearance collar to the shaft. These are specifically designed for use on the very small amount of exposed shaft found on various French boats. You need the 25mm size:
http://www.boatzincs.com/beneteau-donut-collar-specs.html
Yes, it must be on the shaft, forward of the prop, in the water. It will do nothing if installed dry and inboard.Does it need to be on the part of the shaft coming outside of the boat (behind the prop)? Will it work if you just installed it inside?
For Max Props only.Has anyone heard about prop zincs with a supporting aluminum ring molded in to prevent this? I though I saw that on a web site but can't find it now...
If you isolate your zinc from the bronze prop with some coating your are defeating the purpose of the zinc.I think this (plus nail polish) is the answer. I actually do have a max prop.
Now I need to connect this product with my diver!
Ron,Yes, it must be on the shaft, forward of the prop, in the water.
