If you are going to go to the time and expense, read don Casey's recommendation for barrier coating in his book. The thing most of us fail to consider is that it takes a long time for the hull to completely dry out. This results in failure of the barrier coat. It is worth reading.Isla-Mae said:I am restoring a 1977 O'Day 25. How important it it that I have a barrier coat put on the bottom?
If your boat's hull has blisters you should repair it and go with a good bottom paint. I've been using Super Shipbottom Ablative bottom paint for years now and I like it. This paint has a high copper content and it can be painted over bare Fiberglas and most bottom paints. It has it's own primer built right into it. You only need one coat which should last about two seasons with touch ups. I wouldn't bother applying a barrier coat.I am restoring a 1977 O'Day 25. How important it it that I have a barrier coat put on the bottom?
Have to agree with only barrier coating a dry hull and that doesn't mean dry to the touch. Unless its been dry stored so the hull has a chance to dry out over the winters, out of the water for a very long time (Months to years vs weeks), or been peeled, chances are that its not dry. Better to just forget the barrier coat or you can make what is a minor issue (if an issue at all) a much worse problem.
Agreewetass said:Have to agree with only barrier coating a dry hull and that doesn't mean dry to the touch. Unless its been dry stored so the hull has a chance to dry out over the winters, out of the water for a very long time (Months to years vs weeks), or been peeled, chances are that its not dry. Better to just forget the barrier coat or you can make what is a minor issue (if an issue at all) a much worse problem.
