Where Can I Find an Auto Battery Filler
397
Macgregor M25 trailer
I've been trying to find an automatic battery filler. I'm putting in 4 6 volt batteries and were I want to put 2 of then there is no easy access to the top to fill them, without moving them each time.
I've seen the fillers, but do not remember where. I tried google and just came up a bunch of squeeze balls, funnels ect.
Anyone out there know of any?
Fred Villiard
Dec 11, 2008
1,338
catalina C27 stillwater
Fred Villiard
Fred-
Do an internet search for "Battery watering kit" You will find several available, such as here: http://www.buggiesunlimited.com/pro..._medium=feed&gclid=COvijI-MmLQCFY1DMgodoQUA-A
These are more often used for golf car batteries, but the setup would be the same. the only issueI perceive is that you will want a system that has its plugs either individually installed, or in a bank that has same hole spacing.
These things are nice... Most are operated witha squeeze bulb. Each cell's plug has a float and when full, it closes and diverts water to the next cell. When all cells are full, the squeeze bulb gets firm and you know you are done.
I have one ona golf car and it sure took the drudgery out of keeping the batteries topped off, even with easy access!
Dec 11, 2008
1,338
Did a little more searcching and Flow-Rite seems to be the most affordable brand.
FYI
Dec 28, 2009
397
Phil, Thank You!
I tried google search before and didn't turn up anything, just not asking it the right thing.
I use the computer most of the day doing electronic modeling, but I'm computer illiterate when it cones to searches and I have not found a keyboard that can spell worth a damn either.
Thanks Again
Fred Villiard
jerry
Jun 9, 2004
64
Catalina 320 500 Stockton, Mo.
RV stores. Got mine at a Ford rv shop. Great product. I check and if needed fill my batteries every time I am at the boat. Takes less than a minute.
Dec 28, 2009
397
I"ll try again, Phil set me straight to google for "battery watering kit" I found a place local in Binghamton that catered to golf carts and RVs that had them in stock.
Thanks Again everyone
Happy Holidays
Fred Villiard
