Classic Plastic 9.2
423
S2 9.2A Newport News, VA
I'm assuming that I've missed this being posted somehow, but a quick search didn't turn up anything, so I'll put it up just in case it hasn't.
This is a one-page, "classic plastic" article on the 9.2 from the October issue of Cruising World.
Here's a link to a .pdf of the article.
http://www.yousendit.com/download/WUJZSU5FNkdsUjlqQTlVag
Got out on the water twice last month. Am now sidelined with a leaking fuel line on the Yanmar. Awaiting a replacement from the typically pokey Torreson folks. My goal is to get in a sail at least once a month this winter, so I hope they're not too pokey.
Current foremost project is finding room for two, 200 AH 6 volt AGM batts a friend found for me used but cheap. Actually, they're from heavy duty UPS units. Never used, but out of date. Test well.
John
6,244
S2 9.2a Fairhope Al
This is a one-page, "classic plastic" article on the 9.2 from the October issues of Cruising World.
John
thanks for the post BB its always nice to see lit on theses boats......i think you will be happy with the AGM's..... can you tell me how much theses weigh each ....i have three for my boat ....i made a new box base in the existing compartment and they fit great....
regards
woody
woody, three SIX volt batteries won't help you very much, two of them will, right?
Apr 27, 2011
423
Three six-volters would definitely be an "odd" number to have!
My AGMs are 72 pounds each and boy, I wouldn't want to have to heft anything heavier.
John
Apr 27, 2011
423
BTW the article says you can convert the port settee into a double berth. Does yours do that? That'd sure be nice, but I don't think it's set up that way.
John
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
opps........
........should have said 3 12volts my mistake..... i have 3-12 volts that weigh 72lbs each for a total of 216 lbs ...i put them in the original battery compartment ...had to dig out all the 2/4s that the factory had made in to a battery compartment to hold only 2 group 27's it will give me a double set paralle and a single one for starting and back up.....i glassed battens in the box area to set a pieace of 1/2 inch ply wood that is fiberglassed on both sides and a gel-coat finish...then glassed that in on top of the battens.....i am able to strap them down snug and secure with a spacer between each one.......i will post pics when i get home as i am in Hilton Head SC untill monday.......
i am also putting a 12 volt up foward ahead of the water tank in that little storage compartment in order to run a windless.....reason is i can run charging circute from the rear a lot cheaper than i can run tinned battery cables.......so i will have 4 ...12 volts on board
regards
woody
6,244
S2 9.2a Fairhope Al
John
i dont know how they planned to do that with what i have on my boat but i am working on re designing it to do that with minaimal effort....sorry for the spelling i am on my note book and dont have spell check.....
Apr 27, 2011
423
Woody,
We'll look forward to the pictures of the battery compartment.
To further diverge from my original post: I looked up Covington, GA. I see Lake Oconee not too far away. Is that where you'll launch her? Are we all invited to the launch party?
John
Sep 15, 2009
6,244
S2 9.2a Fairhope Al
Woody,
John
that lake is alittle shallow for a 92a......i am planning on mobil bay/fair hope al......as far as the party goes the more the merry.....bring llts of booze....my buddy always says " When i drink every body drinks...When i pay everybody pays.."
regards
woody
Nov 14, 2012
8
S2 9.2A Edmonds
Hey thats my boat! (and me at the helm). The article in Cruising World is an edited down version of the longer one that appeared in Good Old Boat a year or so ago.
