Lining up my mild winter / spring projects and got a few questions.
1st Question
I'm aware of the deck core and care needed when bedding hardware. How about the pushpit and pulpits? Does that location have cored deck? There is some rust staining coming out from under the mounting plate of the pushpit so I may re bed it in the spring.
2nd Question
Has anyone replaced the jib standup blocks with a jib track for more adjustment of the jib sheets? I took off the bad jib standup block on the port side but waiting for warm spell so I can pot the holes with epoxy before mounting new blocks. Wondering if I should go through the trouble of a track or stay with the deck mounted blocks.
3rd Question
Is it okay to use the winches for spring lines running towards astern to pilings? Would it be a better idea to plan on mounting cleats mid boat?
4th Question
I was crawling around under the cockpit and saw that something was epoxied to the underside of the cockpit sole. It had been cut off cleanly and the epoxy looks original. Any ideas what might have been there? Photo below.
1st Question
2nd Question
3rd Question
4th Question
