Bob, we have an O'Day 272 and installed AC on board 4 years ago..We installed a 12,000 BTU Mermaid, but it will not cool the boat during the daylight hours in the summer...temps of 95 and above...I've fiddled with it these past four years and have finally got it to cool down pretty well with every nook and cranny covered up...all hatches/ports, etc....giving the boat a shower helps as well. finally ended up installing a 6 inch inline duct fan in the main duct as it comes out of the mermaid....I would not do 4 inch ducts. We installed the AC Compressor in the area under the v-berth cushion that previously used for storage.....Your boat has considerably moreHi,
I would like to install a/c in my O'Day 28. Not to sure of where to put the compressor, about 12X16X12 it's a small 5000btu unit.
Has anyone put one in?and if so, where?
Thanks,
Bob
Bob,Pat, Thanks for the info. I was thinking of placing the unit under the nav station or under the sink in the head. I looked at the smaller units so I could run it on a honda generator while on the hook.
Fair winds,
Bob
Yes, that was one of the first things....there are several issues..one we made too many 90 degree turns for the 4 inch ducts...ea. 90 degree turnPat ........have you check your unit to see if the freon pressure level is to low or to high? To high and the compressor will not operate correctly and you will not get to proper cooling temperature. To low and unit will not cool to the proper temperature or freezer up. A good a/c mech will know how you say it, dial it in to just the right pressure for maximum cooling temperature. Same technique used for your refrigerator/freezer..... Also for extreme summer months I will place a fan down next to compressor to help cool it down ...By doing this I am able to pickup an extra 5 to 8 degrees of colder air coming out of the ducts. 12 Btu's for a 27 for should be plenty. Btw....... All my sunbella hatch covers are insulated with foil backed foam . Also foil backed foam inserted between vinyl head liner and deck. Hint.....I found the foil foam backed material .....dollar sunshades from my local dollar store.
results in a 13-14 percent reduction in static pressure.. Also, we don't have
a bimini or dodger to block the heat of the sun. Next, we first installed the thermostat in the head right where the sun would shine on it and keep the compressor running because the unit never would shut down. (we've moved it). I've now made foil covers for each interior hatch, and I use a large beach towel on the main hatch boards (a bit of a pain)....On a 90 degree day, our unit does okay during the daylight hours. At night we cool quickly down to the upper 50's or low 60s which is wonderful for sleeping and a great way to wake up. Kansas has been in terrible drought and the outdoor air temperature was over 100 degrees in 2011 for 48 days in a row, reaching 109 three times. This past summer we put in late may and by July had to be thinking of pulling....but again had days that reached 109 ...that is too hot for any ac to be cooling something pretty exposed....the inline fan made a huge difference....other people at our club have the same issue...with compressors running so long, the units freeze up trying....I've exchanged over 100 emails with Mermaid's President who has been fantastic in offering suggestions..our lake is now down 8 ft. and it's very doubtful anyone will be sailing a keel boat this year...thanks for your suggestions.
Our issue continues to be 4 inch ducts and too many 90 degree turns...reduces the air pressure as you say...also used flexible duct which again cuts down further on air flow. ..I'm thinking about getting rid of the flex duct and just going with the smooth...as I stated earllier, we have really hot weather here in wichita in the summer and I'm not really sure any ac can cool a boat on a 109 degree day...I'm not complaining, just wishing I had done a couple things differently....the evening and nightime cooling is really incredible...there is one other drawback....we do not go anchor/cook/out nearly so much...sort of turns us into hermits...it is either funny or sad, as we get to the club which will often have a full parking lot, but no one can be seen as everyone is below trying to keep cool...when it is like this, it is better to just go to the boat and head out sailing. .PatrickWe installed a 12K Btu in an Ericson 35 and it cooled the boat to comfortable in just a few minutes. Units freezing up means you have the capacity to cool but are not moving enough air. The unit should never ice up.
We need to do that as well. I've laid out a dizzying array of beach towels and the like to cover hatches but that only works on a relatively calm day and there are not too many of those in Kansas....Our lake is so low right now that we might never get back in the water, but we must shop for those before going back in.. I'm considering a bimini plus dodger. Bimini is first though.Hi Pat, We have a white sunbrella boom tent and a small tent over the front hatch. This does help to keep the afternoon temps down.
