Floating dry storage
There is an alternative you could call floating dry storage. It's called a Hydro-Hoist which is basically a pontoon boat with sailboat bunks on top instead of the usual deck. The pontoons are flooded to submerge the hoist, the boat is moved over it, then air is pumped into the pontoons forcing most of the water out . My sailboat is lifted clear of the water except for the lower 3 feet of the keel and some of the rudder. The manufacturer's website has some pictures unfortunately none include a sailboat. http://www.boatlift.com/ But it works fine with my Wavelength 24 with 4.5 foot draft. The keel goes thru the middle opening.
