.................. is proving to be difficult to live up to (in more ways than one)
I've finally decided to install two Blue Sea Systems terminal fuses #5191 (shown below). One on the houses battery bank and one on the single starter battery. This is a quick and easy way to ensure that any short circuit in a heavy cable within the engine compartment (the most likely place to happen) is not going to result in a melt down of the battery switch (250A rating) or worse.
A few details about the electrical system read as: The starter pulls about 135A on a cold wet day. It's supplied by #2 AWG cables with an ampacity of 200A. Perhaps a little on the light side but still does the job very well. From this, a 200A fuse on each battery #1 and #2 should serve the purpose.
However, this is only true when the battery selector is in the "1" or the "2" position but not on the "BOTH" position. The switch is normally on "BOTH" when motoring for charging. On "BOTH", we would see a flow of 400A before the 200A fuses would blow.
If the two fuses were to be reduced to 150A each, this would be too close to to the draw of the starter when only #1 battery was used.
I want to avoid installing a 200A fuse past the battery switch because this is greater than 7" and would also be difficult to access at the best of times.
Any thoughts on how to safely fuse this wiring without rewiring the entire setup would be greatly appreciated.
Thanks as always.
Thanks as always.
