These look like they would take some work out of launching and retrieving a trailerable. http://www.surfixinc.com/surfix_trailer_bunkslides.html
just because the boat weighs 4000lbs doesnt mean it will have 4000lbs resistence... it can have a considerable amount more or a considerable amount less, depending on the friction of the surface its trying to slide against.The winch on your trailer is only good for about 1000 lbs. of pull and your boat is between 2000 and 4000 lbs., the only way you can retrieve a boat of this type is to float the hull almost the whole way onto the trailer. The winch is used to lift the hull up over the up swing of the bunk fronts, There maybe some added benefits in applying to the 6 to 18 inches front end of the bunks but, no more.
Type your reply / post in a word processor first, then cut and paste into the reply box when you are done.I just typed a lengthy, hopefully and iinformative reply,when I hit Submit Reply I lost the entire Sailboatowners site :cry: ! Last time this happened to me, Phil said it was very rare, maybe some how I got timed out or took too long typing.
David S
Here read this forum.I just typed a lengthy, hopefully and iinformative reply,when I hit Submit Reply I lost the entire Sailboatowners site :cry: ! Last time this happened to me, Phil said it was very rare, maybe some how I got timed out or took too long typing.
Anyhow, I built my own bunks planks and carpeted held up on their ends and springy in the center to conform to the hull curvature, boat appears to set there on nicely. I am going to submit this portion NOW.
David S
