Sand Anodes And Reuse?
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
This spring I put on brand new "zincs" or anodes as they should be called. The do have some very light corrosion and because I'm cheap I was considering just giving them a good sanding to expose the raw metal and then put them back on.
Sound like a good plan?
Likes: 1 person
Oct 2, 2008
3,815
Pearson/ 530 Strafford, NH
Cheap, I'm saving the little pieces to cut down for the anodes on the outboard. Too bad you couldn't mail them in for money like your old jewelry.
All U Get
Oct 17, 2011
2,809
Ericson 29 Southport..
Shoot, why not? There's no use replacing a "part" that's not worn out.
Scuff it a little on the contact surfaces as well..
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
I personally do not think that zincs are anything you want to skimp on. They play a pretty important role in keeping your underwater metals in tact. A typical zinc costs about $6 (go to Boatzincs.com) or you can get a price match at you-know-where.
RichH
Feb 14, 2005
4,773
Just wire wheel/brush them to remove 'just' the oxide, dont 'sand' off the metal which is the 'active' component of the anode of which the 'activity' is dependent on the MASS (and surface area) of zinc metal.
Feb 5, 2009
255
Gloucester 20 Kanawha River, Winfield, WV
Sanding works, but a wire wheel is easier. I used abrade my anodes down to shiny metal regularly to keep them effective on my fresh water power boat.
Jun 21, 2007
2,118
While I also strive to retard the rate of bank account depletion, I would side with Warren on this one. Getting a full season on a zinc would be pretty darn good for many folks. Even if your zincs still have some meat left, will they protect for another full season? You didn't mention where the zincs are mounted. If a shaft or prop zinc, as they deplete, the zinc metal around the clamp through-holes for the bolts gets thinner and the zinc metal brittle. One day the zinc looks ok, the next day it's fallen off and gone. The cost of a diver to replace one zinc probably would equal several seasons of new zincs -- that's assuming you are in a location where the boat is pulled every winter and you can replace the zincs yourself on the hard?
Feb 5, 2009
255
In my experience, if you have a high rate of depletion you won't have much of a problem with that resisitive surface-coating developing and vice versa.
