Corrosion in Cabin - Help!
117
Catalina 30 Stockton, CA
My 1981 C-30 has been closed up for a couple of months at it's dock and, when I opened it yesterday, I discovered that virtually every piece of interior brass, stainless steel and plated fixtures (faucets, etc.) was coated with corrosion/oxidation. I don't mean spots here and there, I mean coated. The boat is in freshwater in Stockton, CA and I've owned it for close to 15 years and have never had this problem before despite long periods of disuse.
Even the stainless steel oven racks in my propane stove were coated with fine "rust" as were the sinks and nuts on the deck hardware mounting bolts protruding from the overhead. Items stored in drawers and cabinets seem to be OK. The sinks looked like they'd been sprayed with a rusty powder and the faucet spouts and handles were pitted after I cleaned them.
The only thing I can think of that might have caused this is that my solar powered vent had stuck and wasn't operating when I checked it. I have canvas covering the companionway hatch so there wouldn't have been much air circulation. There was no apparent odor nor was there any sign of mildew. Stockton is in the San Joaquin Valley and we have very dry summers and haven't had any significant rain so far this fall.
A friend theorized that my batteries may have been leaking and creating a corrosive environment but my batteries (on a multi-stage charger) don't show any signs of leakage or corrosion. In fact, a brass lamp stored on the shelf above the batteries showed no sign of corrosion.
I cleaned the sinks, faucets and stove with Bar Keepers Friend today and brought any easily removable parts home for cleaning.
What do you suggest for cleaning the bolt-heads, chainplates, etc. and what do you think might be causing this?
Until I can get a new solar vent, I rigged up a computer fan under the existing one to provide circulation.
Apr 2, 2011
185
Catalina 27 Niceville, FL
Corrosion
Happened to a friend. Had a bottle of MaryKate On and Off cleaner that had opened and spilled. Check your cleaning supplies. If no joy, then check batteries.
Jan 6, 2010
1,520
Bob,
I would seem to me that not allowing air to enter & exit the cabin could be one culprit. Temperature differences day/nite can allow moisture to build. In my area during spring & fall, lasting periods of fog causes some mildew in my v-berth area overhead, not much but it's there. These times of year, I use my Waste Marine air dryer. It does the job.
Closing off your companionway not allowing venting, is also a possibility. The vents are there for a reason. I did experience the whitish film you spoke about a number of years ago, but with the WM air drier (2 times a year) has kept this from re-occuring for me.
"let the puppies breath."
CR
May 23, 2004
117
I think you hit the nail on the head. I did have a jug of Mary Kate on board. It hadn't spilled but the cap was loose since it did leak when I knocked it over while on board yesterday. I removed the jug from the boat but need to go back asap since some spilled on the carpet yesterday. It's time for new carpet anyway.
I hope this was the cause since it is a simple fix.
Jun 5, 2012
153
Catalina 30 mkI Victoria, British Columbia
My vote also goes for the cleaner being the culprit. Our men's bathroom at the office also experienced this phenomenon. Everything metal corroded and/or pitted. Screws rusted, stainless of several grades all rusted, chrome pitted, etc. It really freaked us out, cuz if it could do that to steel, what was happening to us as we breathed the air!!!
Anyway, I noticed that the problem was worst in the cabinet under the sink...where a few cleaners were stored.
We removed them and the problem does not appear to have persisted.
Sure makes you think that green cleaners might actually be worth it (despite their poorer performance). I am now religious about wearing gloves to clean with and opening windows!
Cheers,
Mike
May 23, 2004
117
In my case it was definitely the cleaner since everything has been fine since I removed it along with the carpet. I brought all the easily removable items home for cleaning such as pots and pans, oven racks, brass lights, etc. The stainless steel bolt heads, nuts, etc. cleaned easily with Windex and a green scrubbing pad so no permanent damage was done other than the pitting of the plating on the faucets. For the most part, items in cupboards and drawers were unaffected, including the engine and parts under the seats and berths but I need to replace the hose clamps on the head.
My solar vent wasn't working consistently so I hooked up a 12v computer fan to ensure good ventilation in order to clear out any residual fumes.
I'm going to do another posting warning against storing hull cleaners and such in the boat to get the word out on this.
Jun 5, 2012
153
Very good idea Bob!! I've passed the word along verbally to all of my boating friends.
.....Chemicals....scary sh*#
