removing speed transducer - help
221
Catalina 310 USA
anyone here remove their speed transducer while in the water? Mine is not working and want to see if something is clogging the wheel/impeller. I have the dummy plug to put back in but I am somewhat hesitant about trying to remove it.
Any tips? Does the collar against the hull loosen or do I try and loosen the body of the transducer?
500
Catalina 355 Kilmarnock, VA
Unscrew the collar with one hand, have the plug ready with the other hand. Then quickly remove the transducer and insert the plug. You'll get a small gush of water, but with practice you can get it down to only a cup or two. I remove my transducer after every use of the boat, as it seems to attract sea creatures after only a couple days in the slip.
Silvio
Dec 1, 2010
61
Catalina 310 Solomons Island, MD
Yep, what jsalley said.
Mine has a flapper inside the fitting that actually closes off after the first rush of water and keeps it to just a trickle until I put the plug in. I suggest you use two hands, one to grip the fitting and the other to unscrew the cap. Don't over tighten when you install the plug or replace the paddle wheel.
I also store mine with the wheel removed, keeps me from having to clean it so often.
Also I usually rub a bit of vaseline on the threads of the cap before I re-install it, others may disagree but I find it helps.
Oct 17, 2011
221
Catalina 310 USA
Just so I am clear on this, when you say "unscrew the collar", are you referring to "A" in the attached photo? I am able to unscrew "C" (cap?)easily but that did not help.
Thansk,
Matt
76
2005 catalina 310 gig harbor, Wa
As everyone else said its easy to pop in the bung and very little water comes in. I do however leave the transducer wheel in the boat. In over 3 years I have not had one little critter grow on it. I painted the wheel and surrounding area with transducer bottom paint and reapplied once during that time.
Silvio
Dec 1, 2010
61
iSailor,
Grip "B" in your photo and unscrew "C".
If you unscrew "A" you run the risk of breaking the bedding of 5200 loose and having to re-bed the fitting. The cap "C" is just like the screw on cap on your plug.
Jul 1, 2009
221
Catalina 310 Sydney-Pittwater
iSailor,
As per Silvio's advice above and perhaps 'wiggle' the "B" part while pulling on the ring. It may have seized a bit, if it hasn't been removed for a while, and if the o-rings were not greased with vaseline or similar, when installed. Once you grease the rings, it will almost shoot out when collar "C" loosened.
Btw, I am just trialling transducer paint covered with Nappy rash cream. Each on its own lasts about 3-4 weeks before fouled.
Jul 1, 2009
221
PS: Suggest withdrawing the transducer quickly, don't hesitate, this will allow the inside flapper valve to close over. Also, put some Vaseline or white Teflon lubricant on the dummy plug's rings. Messier, but easier.
Oct 17, 2011
221
Catalina 310 USA
UPDATE: finally got around to removing it today. I was a little shocked at how much water gushes in :eek:, but then quickly inserted the dummy plug and all is well.
I found several little crusty critters all around the impellor and once removed it solved the issue.
cheers,
Matt
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
cheers,
Matt
Be careful while cleaning not to damage the little magnets embedded in the paddle wheel impeller.
Mar 22, 2009
360
Catalina 310 Gulfport Small Craft Harbor, MS
Not to change the subject...
But can these transducers be re-calibrated? I think mine is off...I just don't think my boat is really doing 8+ knots of boat speed. I trust the SOG but I don't trust my Boat Speed.
Thanks,
Jim
Mar 20, 2007
500
Thanks,
Jim
The calibration is done on the head unit if it's a Raymarine. The button sequence is in the manual.
Dec 25, 2008
1,580
catalina 310 Elk River
Be careful to account for differences in speed readings between GPS and your water transducer due to currents.
Oct 17, 2011
221
Catalina 310 USA
We took the boat out yesterday and still get a zero speed reading. Assuming that the wheel has been damaged, I guess the entire tranducer needs to be replaced? Anyone venture a guess on $$$?
Thanks,
Matt
Mar 22, 2009
360
My 310 is in Gulfport, MS. If it sits for more than a few days I get enough growth on the transducer wheel that it won't spin...reads 0 boat speed.
So I pull it out and use a stiff toothbrush to clean it off. Works good. I have a "plug" that keeps the water from coming in...but that water flow is no big deal. No need to rush things. Might get a couple of cups of water.
But now my boat speed frequently shows 7.5 - 8.5 knots of boat speed when the SOG shows around 6 knots. Guess I need to read that book on how to recalibrate it.
But the good news is that I sailed 22 days in September, 25 days in October and have 11 days so far in November. What a life...
Cheers,
Jim
Dec 25, 2008
1,580
Thanks,
Matt
Hey Matt, don't bother, just use GPS.
Jun 25, 2012
942
Cheers,
Jim
I pulled my knot meter paddle wheel to clean it off...maybe guessing 8 years ago?. Put the dummy plug in and haven't had to clean it sense. I Just use the gps and that's good enough.:thumbup:
Oct 17, 2011
221
Catalina 310 USA
thanks everyone. I have been relying on the GPS for speed since it stopped working.....I just might continue to do that.
Apr 27, 2010
970
Beneteau 352 Hull #276 Ontario
I had an intermittent speed transducer, or so I thought. It turned out to be the connector at the instrument in the pedestal. Easy to fix.
