I want to install a solar powered vent on my Oday 25 before winter sets in.
I have read pros and cons about the Nico solar powered vent and see one on Defender quite a bit cheaper but I plan to try the Nico 4" vent.
I have a 4" port on the foredeck for the original Oday air intact.
Do I put the new vent in place of the 4" port or put it on the foreward hatch?
On the hatch it will probably get kicked less than on the foredeck but of course the 4" port will make the install much easier. Not sure where it will be safer from flapping jib sheets or even if that is a consideration.
You can see the 4" port in the photo below.
