Hull Deformation
57
Hunter 30 Massena, NY
Just got back from the marina and the marina operator reset out boat on it's cradle, it was off-center and to the back, the boat was moved forward and to the center, unfortunately, the hull was pressed in and now I'm wondering if the hull will retake it's shape without my help or, do I need to do something to help?
xcyz
Hunter 376
:pix:
Sep 25, 2012
57
I got pictures but they don't tell much the hull is pushed up about 1/2" to nothing for about an 8" circle.
xcyz
Hunter 376
Ron,
That does not seem too bad and should relax on its own over time. Faster if it were in warm climate and best if it were in the water.
I've seen much worst and they all relaxed just fine once in the water for a period of time.
Sep 25, 2012
57
Thanks, I feel better, we bought the boat in the water and found the strut bent and then this happening, I'm glad to hear that it should come back
Nodak7
Sep 28, 2008
1,256
Hunter 41DS Punta Gorda, FL
Ron, I had one like this when one of the pads was misaligned. Once the pad was adjusted the hull came back into shape. Could not even tell where it was.
