Hunter 49 Engine Access Improved
7,308
What I don't understand is why Hunter didn't go with the removable floor support right from the initial design. Nice solution.
Jun 1, 2009
1,852
Hunter 49 toronto
Not sure
I've certainly let Hunter know about it. Not 100% certain, but might also affect 50 AC.
This was one thing that certainly got overlooked from a maintenance standpoint. Fortunately, the solution costs nothing, and takes 2 hours
Sep 20, 2006
155
Hunter 49 Mystic CT
Can you say "Sweet!" Thanks Art. This is one change I'll make ASAP. It never even crossed my mind to do what you did here.. Brilliant!!!
Jun 1, 2009
1,852
Hunter 49 toronto
Your stress level will go down by 90%
Everything from changing your oil filter to impellers is a snap when you do this mod.
Be sure to use big fender washers on the bolts.
May 27, 2012
1,152
Oday 222 Beaver Lake, Arkansas
My only concern would be if that section was considered structural. Did they have a reason for leaving it there, making it much more difficult to install the engine? If it wasnt structural, why didnt they cut it at the factory? If so, those 4 little screws on each side wont be up to the task.
Sep 20, 2006
155
Hunter 49 Mystic CT
It's not structural in fact that whole board sits under a engine cover that supports the companionway steps.
The engine cover is to the right of the generator
155
Hunter 49 Mystic CT
Art
I know that's why it's so exciting to see this. You have to be a 49 owner to truly appreciate this modification.
Jun 1, 2009
1,852
Hunter 49 toronto
You are 100% correct
It's not structural. Just one of those things a builder does that can be improved upon. No big deal...easy fix.
Feb 16, 2012
198
Hunter 45 CC Alamitos Bay, Long Beach
What make, and size of generator is that?
Jeff
May 27, 2012
1,152
I wasnt thinking vertical structural support, but lateral. Such as bumping a dock, would it transfer loads to the other side. No biggie, just observing.
By the way, I like how they encapsulated the genny, thats gotta be pretty quiet.
Jun 1, 2009
1,852
Hunter 49 toronto
Not even close
The 49 weighs 32,000 lbs. it is built like a tank.
The floor adds very little, if nothing structurally to the boat.
The genset I have is a 12kw Fischer Panda, which I just love.
It is super quiet, in part because of the excellent install Hunter did with a water / gas separator. Sitting in the cockpit having dinner, you can't even hear it running. Way over-rated for the boat. You need to run all your airco units etc to ensure you aren't running it with too low a load.
May 27, 2012
1,152
While you dont want to run the genny at low load for long extended periods, as long as it gets a good workout every once in a while it will be fine. In fact gennys that have started using oil from constant running at low load, most often come back after a full load run of 10 to 20 hours.
Very nice boat by the way, I can only imagine how sweet something like that is.
Sep 20, 2006
155
Hunter 49 Mystic CT
Well the weather is finally warming up and I was able to get to the boat today and make this modification. Already I'm seeing the benefit as I dropped a screwdriver that rolled under the engine.
Thanks Art!!
Jun 1, 2009
1,852
Hunter 49 toronto
Easy modification, huge benefit
Thanks Art!!
Here's what motivated me to do it originally.
The coolant drain valve that Yanmar put in fell apart.
With the engine running, all the coolant drained into the engine well, running over the alternator, splashing all over the place. I couldn't imagine how I'd ever clean it up.
So I just stared at the floor which blocked 80% of the engine access, and said, "this is dumb". I actually used another word other than "dumb", more or less describing what exits a cow's "stern". You get the idea.
So I just pulled out a jigsaw, and that was that.
I have told a number of people about this modification, and everybody does it immediately. Glad it worked for you
I've got a ton of really neat 49 upgrades & fixes if you're interested.
Arthur
Sep 20, 2006
155
Hunter 49 Mystic CT
I'm always interested in making my boat better. I've already done the aft head fix you recommended. It's amazing how little things can improve tour boating experience.
Dave
