I am needing advice on battery. On boat yesterday (on cradle) and finished winterizing
the engine...I noticed that one of the batteries had corrosion on the terminal....although the engine started right away, I decided to check the fluid level and found 4 of 6 cells on one of the batteries were basically dry...i.e. no fluid visible... I filled the cells and turned the charger back on (Statpower for 2 batteries) the light on the charger indicated "absorbsion" mode.
What have I done wrong? was it a mistake to leave the charger on or did I do the right thing.
I'm certain I will plan on replacing this battery in the spring. Thank you for your thoughts,
Patrick
Patrick
