rub rail
131
Hunter 23 WIll be at a Navy base
I have looked and looked for rub rail. At last I found some but you can not buy pieces. So my thought is to replace the entire rub rail and the part that screws against the boat. I have had an impossible time measures the width of what exists. If I just replaced the entire thing all the way around the boat does the width matter in that case? As long as it is wider would I be okay? It is not cheap doing it this way but this may be the only thing I can do.
Jun 27, 2011
111
Macgreggor/Balboa 26 25/26 Baraga
Webco has rub rails also.
