Gasket for Yanmar SS exhaust elbow
22
ODay 322 7385 San Diego
Hi, after some issues with my engine, Im going to change the Exhaust U type elbow for a SS one.
I found a vendor in E bay offering the part for 186 dlls, buy he dont have the gasket, can you help me find out how to make a gasket for this elbow
Thank you
Oct 29, 2005
2,366
Its a simple graphite gasket. You can buy the material from auto shop and cut it yourself. no need for prefect dimension.
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
order
order one from Yanmar parts near you and would love to see the stainless elbo you are getting or any info where who you got it from.
Nick
Nov 6, 2006
10,253
Don't know which engine, Jose.. but if a 2GMF the gasket part number is 128170-13201. If you have a 3GMF, the gasket part number is 128370-13201.
As has been noted, you can easily make this flat gasket from graphite gasket material, using either the old gasket as a pattern or the end of the ell adapter for a pattern..
Jun 7, 2007
515
Hunter 320 Williamsburg
Where the gasket goes
Just to clarify, the gasket isn't for the elbow but rather the manifold. You have to remove the two piece together by pulling the four bolts to the manifold. Then you need a gorilla to separate the two unless you dip the elbow in an acid wash instead. Any Yanmar dealer has the proper gasket.
Oct 28, 2005
89
Hunter 31 Portage De Sioux, MO
I am sure you have a Yanmar dealer close to you in San Deigo. The part numbers given to you are correct in the afore mentioned response. Go with an original gasket. Don't make one. Unless you like redoing your work. Just did the same thing on my 2GMF. Think is only a few bucks. Make sure you scrape off all of the old one, so there will be no leaks. Good Luck.
Jul 14, 2012
22
Thanks for all the replies,
I found Dependable Marine in San Diego, I will call them to ask,
is absolutely necessary to take both pieces togheter and then separate them, is not possible to take out only the elbow?
Jul 14, 2012
22
Hey Deadline is absolutely necessary to take both pieces togheter and then separate them, is not possible to take out only the elbow?
NYSail
Jan 6, 2006
3,187
Beneteau 423 Mt. Sinai, NY
Take both pieces off and replace. Just undo the 4 bolts, put the new pieces together. It's much easier and why not..... You have an entirely new section.
Jul 14, 2012
22
Im sorry but i got confused, what are the two pieces we are talking about , elbow and manifold or elbow and gasket, thank you and sorry for this question
Dec 19, 2006
5,836
Elbo
I have seen this type of elbo on the yanmars at sailboat shows and have asked about it and they said not for sailboat and it could allow water into engine.
My engine exhaust hose does have a loop before exiting the boat and think this type of exhaust elbo would improve the engine performance for sure but worry about water backing up into the engine.
Nick
Nov 6, 2006
10,253
The guidance from Yanmar is that if the exhaust inlet to the ell is 8" or less above the water line, then the upside-down U outlet is necessary along with an anti-siphon valve on the cooling water line to the ell.. This was noted in the 2QM manual, but I am thinking it is the same for the GM.. If you have a U shape, then ya probably should go back with same.. If a straight one, then you may be OK with the stainless part?
Of note on that stainless outlet is that the Yanmar cast part (not the U shape) has the exhaust in an inner tube.. the water flows in an annulus prior to being dumped into the exhaust stream through a circumferential opening a couple of inches downstream of the hose connection.. May not make a difference other than the OD of the tube running much hotter, but ya never know.
EDIT NOTE: The water inlet to the hot gas part of the outlet pipe MUST be lower in elevation than the lowest part of the exhaust outlet port of the engine, otherwise water will get into the engine. The annular opening inside the Yanmar part (where the water comes out into the exhaust stream) is an inch or so below the gas inlet to the elbow. It looks like there may be an annulus in the stainless part, but I can't see the place where the water gets mixed into the exhaust stream.
22
Nick
Hi Nick, I have now a U type elbow that has the form of a loop itself and also the exhaust hose has a tall loop near the exit at the transom.
So I think the engine will be protected with this tall loop and get a better performance with the SS elbow, at this moment the U type looks like is almost clogged with dirt and rust.
Dec 19, 2006
5,836
Yanmar tech
Next time at a sailboat show I will want to ask the yanmar techs at the show,I am pretty sure we need the u mixing elbo and I am not ready to experiment with my 07 3YMG yanmar just yet and so let us know how it works out.
Nick
Jun 21, 2004
21
Hunter 34 Cape Coral, Florida
The loop at the transom is to stop seawater from comming in through the exhaust outlet in the boat. The mixing elbow mixes with the hot exhaust and cools it so it doesn't burn up the exhaust hose. Water infiltration from this type of exhaust may alow the water from the engine cooling to migrate into the engine because there is no loop. I would be very concerned about using this. If you do try it, post your results for us... If you will..good luck
Mel
S/V Sea Puppy
