Solar panel Frame
11,772
I made my Solar Panel frame on my 07 H-36 using the arch,take a look and see wha you think and only have a piece of aluminum angel iron.
Nick
Looks good Nick! I use a lot of the Gemini Split Rail Side Mounts... Saves the cost of two fittings and is a rather elegant solution to over the bimini solar mounting. They work for many other things to like collapsible bimini's, dodger hand rails etc. etc...
Dec 19, 2006
5,836
Hunter 36 Punta Gorda
Fittings
I was going to do exactly what you show in your photo but than decided to use the 2 clamps for a stronger mounting and did not trust that split rail side mount for long term strength.
I do have the split rail side mounts and will use them for some thing else but that's just me always making things stronger.
nick
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
Thanks for posting, looks very good.
I intend to do the same job on my 356 so was happy to see how you did it. Please put up a few more shots after you get the panels installed with the details of the controller used and typical power generated per day.
Bob
