How Many of You Hate Making up the V-Berth???
Sumner
Jan 31, 2009
5,254
I just posted the following on the MacGregor board, but thought that it might be of some interest here.
I'm the one that gets the job of making up the V-berth bed in both boats and I've never liked it. First we started with full size sheets and blankets and they were a pain to get tucked under the mattress and you had all of that extra material.
Then we cut the sheets and blankets to better match the V-Berths shape and that helped but I still had to climb up in there and try and do the job.
Well that is a thing of the past now I can make the bed in the Endeavour standing up at the head of the bed and in the MacGregor pretty much the same way. I'm sure someone else must of done this so I'm not saying that it is original, but it sure is handy.
The 3 pages of pictures and info starts here...
http://purplesagetradingpost.com/sumner/endeavour-canvas/canvas-15.html
...but I'll summarize below.
The key to this working is cutting the mattress into 3 sections...
... and making covers for them. We have been sleeping in both boats on a mattress configuration like this for the past couple years and it feels like one continuous mattress under you.
Next step is to ...
...cut big hunks out of the fitted bottom sheet then...
sew it back together.
Next cut the top sheet and hem it so ...
...that it is wide enough to go over you but get rid of all of the access material. Then attach a slip cover to the ....
...end of it like above (sorry for the color change, but the sheet was cut & sewed the same).
To put the sheets on you start like above and you can bring the foot mattress back to you where you are standing at the berth. Put the cover on the mattress like above and leave the top sheet off to the right.
Next pull the bottom sheet over the foot mattress and let the elastic band pull some of the top sheet back under the mattress section like above. Notice that the top sheet is still off to the right.
Here is how things look at this point. You don't need it all laying out like above. I did that so that it is easier to see what is going on.
Next you just fold the top sheet back over the bottom sheet and the mattress. At this point you can take the mattress section with attached sheets and slide it forward on the V-Berth platform. Slide it in a ways and then take the second mattress section and lay it on the platform and pull the fitted sheet around the sides and under it. Then slide it and the foot section forward some more into the V-berth. Finish by doing the same with the last mattress section.
Now you just made the bed without getting into it. We also cut top blankets like the top sheet (with no sleeve at the bottom). If it is cold put how many blankets on the top of the sheets/mattresses as you slide them forward
This is one of the most practical things we have done to the boat. No extra bedding down at the foot. The top sheet doesn't pull out down there and you can make the bed standing up in the cabin. You can make the bed in less time than it takes to read the above. We love it or should I say that I really love it as making the bed is my job.
Again more pictures and info starting here....
Sum
[FONT=Arial, sans-serif]============================[/FONT]
Our Endeavour 37
Our MacGregor 26-S Pages
Mac-Venture Links
Erieau
Apr 3, 2009
209
Oday 25 Erieau
When I read the thread title, I practically shouted, "Heck yeah, that's me!"
Absolutely brilliant, Sum. I'm making new V-berth cushions this winter, and by golly this is how I'll be doing it.
Thanks!
kenn
Apr 18, 2009
1,271
CL Sandpiper 565 Toronto
Another Sumner gem. When is your book coming out?
We're still in the "sleeping bag plus a sheet" mode, since we usually have to put bedding away during the day. But we do aspire to a boat with a made-up bed. :D
Gail R
Apr 22, 2009
261
Pearson 34 Freeport, ME
We just use a fleece sleeping bag. Roll it out, and it's done. Takes about two seconds.
I've thought about making custom fitted sheets for the V-berth, but I don't like cotton on the boat. It holds moisture, gets clammy on cool days, and is prone to mildew.
So far the sleeping bag works great, but I'm thinking for longer periods on board, we might want another solution.
WayneH
Tartan 37 287 Pensacola, FL
Having heard from the sailors north of Memphis, Ohio, here's the take from someone south of New Orleans, Louisiana.
Gulf Coast, August, nighttime temperatures near 85, no breeze. Not good conditions for a sleeping bag. The admiral made fitted sheets for V-berth and they work great in those conditions. Although she did yell at me when I put my fingertips on her leg. "Tooo HOT!!!!"
And because the water outside the boat never gets hard around here, we do bring the sleeping bags down to the boat for January. I think it's the 5th through 8th this coming year. (Winter, that is.)
Beneteau 323 Annapolis MD
sheet-bag for any bubnk
I found a good thing (if you will keep doing overnighters) is to get a king-size bed sheet and fold it in half length-wise. Sew it half way up the side. I left the foot open to poke my feet out if I get too warm, so you could use a contoured/elasticized top sheet for this. Thus, you can fold back the upper part to get in and out or to cool down some. It's a top AND bottom sheet and sleeping bag this way. Fold it up and put it in a pillow case.
Gary_H
Nov 5, 2007
469
Cal 2-25 Carolina Beach NC
No problem making up the V Berth. My problem is getting in and out without smacking or smooshing my wife. Going in head first requires getting turned back around. I'd almost rather sleep in the salon berth.
Jun 1, 2004
8,351
I don't have a vee berth on my boat, but....... I call it the GARAGE. I hate sleeping there.... it's like a coffin. On a larger boat, like my buddy's IP31, the vee berth is pretty damn comfortable for one big guy.... but it has a sunny, opening hatch and plenty of room to sit up, put your feet on the deck and get dressed with the door closed.... NOT on a Cat27 though.
225
Catalina C25 Eagle Mountain Lake
Really? I like the v-berth in my C25...it's where I sleep, nap, read....it's cozy for one, and that big hatch overhead brings in alot of air when there's a good breeze.
Using sheets is a very French/English thing.....although I use sheets at home......when I lived in Germany I got used to just a fitted sheet over the mattress and a bettdecke (covered comforter). The covers are washable and the bettdecke is hung out to air during the day.
I use the same concept in the boat...fitted sheet over the cushions and an unzipped bedroll as a cover.
I do like the OP's effort though...good job and an elegant solution!
Sumner
Jan 31, 2009
5,254
I don't have a vee berth on my boat, but....... I call it the GARAGE...
I remember the "garage" :).
I don't have a real solution for that, but...
...putting in the platform above....
http://purplesagetradingpost.com/sumner/endeavour-inside-mods-2/page-22.html
...did help Ruth and myself get into bed easier as the berth is a long ways off the sole in the Endeavour.
On the sleeping bags....I lived in Wyoming for years and spent a number of nights in a bag and could do it for a few on the boat, but we wouldn't use one at home and we don't want to use them on the boat for a month or more at a time, especially in Florida. We did spend a couple nights on the Mac when it was in the low 30's in December...
http://purplesagetradingpost.com/sumner/FL-fall-2010/FL-Fall-10-15.html
.... and then we really liked the fact that the V-berth and cabin are small and easier to heat (we also had the pop-top down to close things up as much as possible). We were using every blanket we had on the boat and had on long underwear to boot. The cold did result to a marriage proposal in the middle of the night and an acceptance :).
Sum
Our Endeavour 37
Mac-Venture Links
Oct 10, 2009
1,117
Beneteau 393 Muskegon
Sumner- I hope all these photos and explanations are going to be used for a book on modifying a boat. Incredible stuff, always.
Sumner
Jan 31, 2009
5,254
Thanks and that is what Ruth is always saying. It isn't going to happen though. I have too many things to do yet and I'm too old to get tied up in putting together a book of any kind. The book is on the internet in the form of our site for anyone to see and as long as I'm around and the server fees get paid every year I guess it will be there :).
I'm glad that it is helpful to some and I thank everyone like MS and others that have sites that have helped us out,
Sum
Our Endeavour 37
Mac-Venture Links
