Galvanic isolators
80
hunter 37 cherubini Apollo Beach
For the shore power A/C power.........Needed or nice to have?
I'm an EE and it sounds like BS to me
7,704
Alden 50 Sarasota, Florida
Lots of us, including me, who normally connect to shore power have had galvanic corrosion issues related to stray current on the shore power ground which caused damage to underwater metals including my expensive prop. As an EE, you can easily understand a couple of diodes which are the fundamental component of these isolators can eliminate the problem.
Dec 14, 2011
316
Navicula 430 Hunter Toronto
we have aluminum docks with ladders at our marina......if there where any stray power.........would it not eat the ladders......I dont want to steal this post.......but it could be good timing:)
7,704
In that scenario, the surface area is so large as to make it unlikely anyone would notice for a very long time. Regardless, think of a boat as a battery with one side connected to the electrical system on board and the other to shore power. With an aluminum dock, you are missing one "side" of the battery.
Nov 6, 2006
10,229
one of those things that you should have IF you need one on the boat.. It is not too expensive a "just in case" thing and it does no damage if you don't need one.. but if you need one and don't have one, you'll end up with underwater things disappearing .. like propellers and struts and possibly thru-hull fittings.. A way to find out is to do (or have done) a galvanic survey on the boat in the slip.. or mooring .. Nigel Calder has some good articles about what and why.. As Don says, it is normally not your boat but stuff around you that causes the need..
Jun 6, 2006
6,990
When you plug into shore power you are connecting the the ground circuit in the AC lines on the dock. So does anybody else that connects to shore power. The interconnection of all those boats is the problem. Odds are that there is some underwater metal on someone's boat that is incomparable with your underwater metal. When you connect the two you get corrosion. There are three solutions. Only use gold underwater. don't connect to shore power or get an isolator.
Apr 25, 2007
64
Hunter Cutter 37 Jacksonville, Florida
Its well worth it from my perspective, I had to haul out and repaint when all the bottom paint was blown off the keel, I hope it didn't eat too much off the bolts, ha ha. I also had to replace the prop shaft last trip out of the water, the electrolysis caused the shaft to basically delaminate. One whole outter coating of metal came off like it was really thick bottom paint, but it was metal flaking off the shaft. Heck, I just heard that there are good ones and so-so galvanic isolators, I'm thinking I might be upgrading soon.
Kb
Aug 10, 2010
117
Hunter 36, Quarter Berth Model Placid Harbor, Cuckold Crk, Patuxent River
Wouldn't thermal sacrificial zinc take care of it?
Aug 10, 2010
117
Oops, I meant "the normal" sacrificial.......
Apr 25, 2007
64
I just learned that they make a galvanic testing probe. It plugs into a digital multimeter and goes into the water, and the other lead goes to your engine ground/bonding ground. The dockmaster ended up testing many boats in the marina at the dockside powercord when we were all gone so see who might be leaking. Really cool and it helped us to learn a little more about our boats.
Kb
Verrry expensive probe. Think $100 or better. Nice the dock master had one/got one. We were eating zincs at 1/month. Spent the money. Found the 110 leak. Waiting out the 10 months to pay for.
Jul 29, 2012
80
OK, so here is another question. Shaft strut is bonded to engine and keel bolts. That is all the metal I have in the water except for the shaft/prop. Cutlass bearing is rubber, connection to the egine is through one of those vibration proof couplings (rubber, no electrical connection to the engine)
I suspect the shaft/prop should be bonded, any suggestions on how to acheive that?
11,761
You can jumper across the bolts with #8 wire. This will meet the ABYC standards or install a shaft brush.
