The last of the interior mods....
Sumner
Jan 31, 2009
5,254
...well at least the last for now as we are home and the boat is in FL. Not much to these mods but they did make the boat more liveable.
The first is to help Ruth, who is 5'-2", get into the V-berth easier. It is quite high even for myself and I'm 6'-1".
A two step platform that doesn't cover the whole width of the forward cabin and allows easy access into the head ...
....leaving me a place to enter from so that I still have overhead clearance. I find that it even helps me getting in and out of the berth.
The V-beth sides had rotten wood behind the white fabric....
...with the wood accents. I tore it all out and ...
....redid it with lightly stained plywood.
If you follow the link below you will see why it was rotten. Later I'll post the mod on the new 3 part mattress and how we did the sheets and blankets so that they stay put and aren't all wadded up at the foot of the berth. You also don't have to crawl up in there to put them on anymore.
The next was a ....
....simple platform that makes it more comfortable sitting at the nav. station.
And finally a .....
...framework that mounts our 2 burner stove from the Mac above the Endeavour's stove. We used it when we first moved the Endeavour and at the boat yard for a month or more until I could replace the bottle to regulator line and the supply line to the stove from the regulator, along with a new regulator.
We will take this small stove on trips and use it if we run out of propane or have a problem with the large stove.
All of the above is documented with a lot more text and many more pictures at this link....
http://purplesagetradingpost.com/sumner/endeavour-inside-mods/inside-index.html
Well that is the end of the interior mods when we were at the boat for 3+ months. I still have some other mods to go and some other misc. It was a little frustrating working at the boat with tools on the ground, going in and out up and down the ladder and dealing with the heat and humidity that we are not use to. I feel that if the boat would of been right outside the shop at home the mods would of been completed in half the time. Still it was a good time and after living on the boat for 3+ months, even if it wasn't in the water we are very happy with the boat to this point,
Sum
[FONT=Arial, sans-serif]============================[/FONT]
Our Endeavour 37
Our MacGregor 26-S Pages
Mac-Venture Links
Jun 1, 2004
8,323
Yeah, that weather is tough on us old geezers that are used to the "dry" heat. Perhaps this winter you might tackle project like these stairs, make them so they disassemble. One boatyard I used had a couple of these things and I was lucky enough to snag one. Way, way better than a ladder.
Here's a nice link to inspire you: http://www.laddersafety.org/LadderTypes/MobileLadderStands.aspx
Rolling scaffolds are pretty cool too, especially if you rig something for sun and weather protection while you work on the outside of your boat. http://www.fsindustries.com/more_in.../fortruss_steel_rolling_tower_scaffolds.shtml
5,832
Hunter 36 Punta Gorda
Very Nice
You sure do nice work and amazing the improvements you have made to your boat and one hell of a craftsman.
I guess you are sort a happy to be home for while after all that work and you must be working more improvements for your boat and looking forward to your next trip and can go sailing her in Fl.
We are getting ready to go back home to Fl and can't wait to get back and do some boating for sure,we leave this thursday and been making our last good byes for now to friends and family and drive down south with a stop in NJ and than a day visiting St Augustine,see ya in Fl.:dance:
Nick
Sumner
Jan 31, 2009
5,254
Yeah, that weather is tough on us old geezers that are used to the "dry" heat. Perhaps this winter you might tackle project like these stairs, make them so they disassemble....
Hey Joe thanks for the pics, but I'm ahead of you....
Since Ruth had two foot operations last fall I made the ladder above for her (and I enjoyed it also). It worked great, but you still have to climb it :cry:. It is really heavy so it doesn't move around and the wide flat steps and hand rail work very well.
I'll have construction pictures of it up at some point. It wasn't that hard or time consuming to build.
Nick, thanks and have a safe trip back down and enjoy the water. We will call when we show up, hopefully in January,
Sum
Our Endeavour 37
Mac-Venture Links
Oct 10, 2009
1,099
Catalina 27 3657 Lake Monroe
What a thoughtful couple of mods.
I think it's only a matter of time until Sumner rigs a winch to his boom so he and Ruth can just be hoisted aboard while the boat is on the hard.
May 16, 2007
1,509
Boatless ! 26 Ottawa, Ontario
Sum, as always a great job ! We hope to see you in the Keys this winter/spring. I don't know where you two get the energy, what ever is doing it I want some ! take care, Bob
