That flip up clam cleat looks like a great solution. Very thorough instructions/info on that link you sent also, so thanks again.
The situation where I have been anticipating problems is coming in to our dock, sailing directly toward shore west to east and doing a quick 180 deg turn around a bouy (to south of dock to pull boat away when docked) and catching dock posts on starboard side, where water is a little shallower than depth of keel fully down ... so I will be raising swing keel every time I come in to about half way down, but rudder will be touch and go. Since water depth can vary by at least 12 inches, depending on rain fall and waves from wind and other boats will impact effective water depth i could be scraping bottom with rudder just when I'm needing to make this sharp turn. So it would be nice to be able to adjust the rudder just a hair .. raise it 8-12" to ensure I don't bottom it hard as I'm making that turn. In that regard it sounds like you have rigged a way to raise your rudder when at dock. Could you explain how you do that. Can that be done while under sail? Thanks very much again for your time and very valuable insights.
/Users/williamhunt/Desktop/IMG_5033.jpg
(tried to drop in picture of set-up but guess I'm new at that also)
I'm not that familiar with the O'Day 19 as I am with the 222. The stock rudder blades on the O'Day 222s were molded in two sections at Foss Foam in Fl. Then they were adhered together and pumped with foam.
You can see the seam around these blades where they were put together. Many of these blade have come apart at the seam and eventually the blades break in half. I had two of them break on my boat through the years.
If you're sailing along and the blade pops up 3/4" you will feel a lot of weather helm in the tiller. I think that what happens in most cases is that the blade flexes under the pressure of being off center and this causes the blade to open up and eventually break.
For this reason it's not a good idea to sail with the blade up. I really don't know if your blade was made by this company.
The blade I have now was made a D&R Marine back in the 1990s and it's a solid blade.
I too like to sail up to a dock or my mooring and I do it every chance I get, but there are times when the tide is too low for my rudder blade.
What I usually do is take the sail down and motor in with my blade up and the tiller roped off in the center so it doesn't come in contact with the prop on my outboard.
As far as the rudder blade hold up pendant is concerned, I drilled a 1/4" hole through the trailing edge of my rudder and installed a fair lead on top of the rudder head, and added another fair lead open clam cleat on top of my tiller. I also added a piece of leather around my tiller as a chafe guard to keep the ropes I use to center the tiller from digging into the tiller.
I modified my rudder by adding and O'Day 25 tiller and lowering the pintles down 1". The original rudder blade pendant lines had 12"X 3/16" bungee cord attached to it with a hog ring. What the bungee cord does is put tension on the pendant line and helps to keep it centered on the blade between the inner housing when the blade pops up. Otherwise the pendant line will get jammed in between the blade and the housing.
