Max. heel
172
Hunter 23.5 New Orleans
180 degrees...but you'll probably start to get uncomfortable around 25 degrees.
Kind regards
Hugh
weinie
Sep 6, 2010
1,297
I'd say any woman with heels over 4 inches on a 22 footer is bound to injure herself or others. I'd tell her to save them for apres sail.
MrUnix
Mar 24, 2010
626
Hunter 23 Gainesville, FL
You could probably get her over to 90 degrees, but I can't imagine why you would want to.
Cheers,
Brad
Hunter 29.5 Gloucester, VA
Smart ass comments aside, I had an 81 H22 and as far as we went over was just over 35 degrees before she headed up hard and righted herself
Aug 23, 2009
361
Hunter 30 Middle River MD
As a reasonably new sailor this is a question I ponder myself often. The literature all seems to favor for boats my size 30 ft, no more than 20 degrees and the best balance of speed and control is around 15 degrees heel much more than that and your rudder angle increases to keep you from rounding up and acts increasingly like a brake.
Apr 30, 2011
66
Hunter 22 Lk. Normon, NC
Thanks to those of you who did give real answers. To the others, you would feel more at home on the Sesame Street forum.
Mar 2, 2011
489
Compac 14 Charleston, SC
Perhaps you meant optimum heel angle? I say that's the angle where a boat sails fastest for a given point of sail.
-na -NA Anywhere USA
I have read these posts and some can be considered inexperience or ungentlemen like.
I consider myself one of the foremost on small boat sailing which is based solely on experience and several who raced competively internationally on small boats. Max heel on any small boats 27 feet and under should be 12-14 degrees. Once you go beyond that you are scaring the heck out of passengers/crew even though the righting moment is much higher. In fact you have in most cases more wet water surface creating more friction thus slowing you down. The key to racing is control thru sail either reduced and/or let out with knowledge of sailing tactics to include little to no pressure on the rudder. However, what is small boat sailing is all about. To me it is to have an enjoyable sail with friends and family safely. I have always said, respect the water and it will respect you. So why try to heel over when it is not necessary. I proved that often with the Hunter water ballast sailboats. Take care and God Speed.
Crazy Dave
marxtj
Oct 4, 2011
5
hunter 25 suamico
Funny read....good to know Crazy Dave's final good sense reply. Since I am a new sailor this summer with my husband on a 25 ft hunter, we are having a blast and small craft warning days are the best fun....what type of an instrument is best advised to measure heel angle? Obviously we don't have one.
I think the proper term is an inclometer which you can easily affix to the bulkhead that can be purchased anywhere for heeling .
MrUnix
Mar 24, 2010
626
Yeah, it's an inclinometer.. but I've found you really don't need one unless you are trying to optimize for speed such as in racing. You will quickly discover what angle is comfortable for you, and pretty much all sailboats will round up all by themselves if you drive them too hard (and some sailboats will round up well before you would like them to do so depending on design, rudder length, etc..). Many people, including myself, simply use the 'scream' alarm.. that is, when you heel over far enough to make your passengers scream, you have probably gone too far! :eek:
Beware of the uninitiated though, as they are not used to the heeling motion of a sailboat and tend to sound the alarm a bit early. In those rare instances, I have found that alcoholic beverages can usually readjust their sensitivity to an acceptable level! :dance:
Cheers,
Brad
Sep 25, 2011
161
Ericson 25+ Watkins Glen
Does anyone know what the maximum heel on a 1983 H22 is?
did you get the answer you were looking for?
not sure why some feel compelled to be such smart a**es
this year i am sailing a 1981 hunter 22 , took me a few sails to get the confidence to let her go over far enough to put the rails in the drink.
got to the point where i was rounding up and had to pop the main free to keep moving forward.
was a workout holding the rudder,like others said it acts as a brake since you have to hold it so far over to keep it sailing.
i only have one jib a 110 not sure how it would respond with a 150 ....
some say the 22 is a tender boat but with 1200 pounds in the belly and the five foot swing keel , i have found it to be very stable.
My wife thinks I am nutty. Har Har Har
crazzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzzy Davieeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
