Reefing h260
37
Hunter 260 Sylvan Lake
We have not reefed our h260 yet and all the rigging is new, we have installed the Rams head on the goose neck and have a diagram of the reef line threaded through the boom through the clew reef grommet and back to the boom, are the two mid sail grommets just simply tied around the boom with 1/4 line, does anyone have a pic of that?
Sep 1, 2009
61
2006 Hunter 25 Lake Travis, Texas
tie at your own risk
A lot of folks, including me, won't recommend that you tie those mid sail grommets with anything. You will risk ripping your sail if you do. There is no practical need to do so.
Mar 9, 2011
37
Re: tie at your own risk
So just the clew and the gooseneck grommet and thats it?
Kivalo
Jun 5, 2011
116
Hunter 260 Owasco Lake
I have a ripped sail due to tying the sail down through the grommets.
Feb 8, 2008
93
Hunter. 260 Farr 40.7 Albany-
The grommets are there for a reason. To tie up the slab of sail. But use caution. Tie around the boom with plenty of slack and be very mindful when shaking out the reef.
-na -NA Anywhere USA
take their advice sir. kBeen doing that when reefing since I first introduced the original 26 and then 260 since 1993.
Sep 1, 2009
61
So just the clew and the gooseneck grommet and thats it? Yep, that's all you need to do. It isn't as neat as tieing, but removes the risk of tearing a sail because you tied it and failed to remove the tie prior to shaking out the reef.
Igetit
May 26, 2011
85
Hunter 270 Lake Monroe, Indiana
Thanks for asking the question! Just bought a 270 and would not have known this.
