On my 2007 41DS I am not getting any charging to the house batteries from the Hitachi 80 Amp alternator on the Yanmar diesel. It appears that the starting battery is OK, but I am not sure as so little power is used starting the engine. The Xantrex battery charger is working OK and correctly charges both the start and house batteries.
Before starting the engine the alternator light glows on the Yanmar panel and goes out when the engine runs. Also the tachometer works OK and it gets its signal from a dedicated wire on the alternator. Does this indicate that the alternator is OK?
I suspect that the “Cole-Hersey Solenoid #24117” that combines the start & house batteries is not working properly. I see there is a 16 gauge yellow/red wire that is attached to the positive solenoid control terminal. Where does this wire get connected to? The wire schematics I have do not show where this wire is connected to, but from other posts I think it is the "ignition switch".
Is the solenoid a frequent source of problems? Has anyone out there had to replace the solenoid?
Your thoughts would be greatly appreciated!
