I made a stereo equipment box that sits at the back of the map table under the companion way bridge deck. It also has a two socket 12 volt outlet, the interior vhf radio handset and a few other instruments mounted on it. The wiring exits an 1.5" hole in the bottom of the cabinet and follows a cable race of sorts to the hole left open in the back corner of the map table. I have the cockpit speakers (2 Polyplanar MA905s mounted where the vents used to be in the helm's lazarette). I moved the vents inward a bit to maintain the same airflow (better actually, the holes behind the grate are larger). The cabin speakers are 6.5 inch Pyles mounted in the hanging locker ceilings port and starboard pointing up. I still need to pull the wiring over to the cabin speakers, but they are hooked up to the stereo end. The cockpit sound from the MA905s is awesome.
The stereo is the Fusion AV700 with an iPod docking station. I will be installing a 12 volt 19 or 22 inch TV (Symphony i believe) on the surface above the map table eventually. That should round out the entertainment system I had plans for. The TV will swing out to be viewed from either the cabin or cockpit (although watching it from the cockpit is not the primary objective, but you never know when at a mice anchorage someplace you want to enjoy the fresh eveing air, sip refreshments and catch a movie or ball game, yes a flat HD antena will be installed too). We have pandora playing from one of our iPhones in the docking station which is better than satelite radio IMHO. My iPod also has 6500 tracks of music and books from Audible available.
I will add a complete writeup on my website and the owner mods section of this site once I get the last pieces (the TV monitor) installed and configured.
