Cetol Removal-Chemical or Sand It Off
Ducati
Nov 19, 2008
380
Boatless Boatless Annapolis
OK the Cetol has to be removed from the toe rail and then reapplied.
Is there a chemical paint/varnish remover that's safe if it lands on the gelcoat or do I have to use elbow grease and sand for hours?
Thanks
Jul 5, 2007
196
Kenner Privateer 26 schooner, Carlyle Illinois
heat gun
A little heat makes it scrape off easier. Scraping is easier on the wood if you are carefull. Sanding can wear down the wood too much.
Ducati
Nov 19, 2008
380
Heat on gelcoat...may be worse than the chemical
I know that heat does do a good job but I'm thinking that by not being careful (I can do a good job of not being careful) could accidently fry/burn the gelcoat.
Then I have another issue...
Dec 11, 2008
1,338
catalina C27 stillwater
Cetol can be re-applied over old Cetol with only a light scuffing... I might simply dull it with some bronze wool or some 320 paper and then go back over the old with new.
Jan 3, 2009
821
Marine Trader 34 Where Ever I am
Which is why I ask and no answer, why take it all off and apply a new coat? Chuck
