Aircon sea cooling water pump
2,366
I have a Cruiseair 12000btu aircon with sea cooling water pump. I noticed this pump has been leaking luboil for the past years. I want to put a stop to the leak. Anyone has any or written a service instruction for fixing his pump? I don't have the pump details now but it is quite commonly found in marine aircon and even in WM site.
7,755
Alden 50 Sarasota, Florida
Most OEM pumps are CAL pumps which are throw-away pieces once they start to fail. If it is a CAL, just replace it with the appropriate size March pump
Nov 6, 2006
10,257
Don, Yep.. the CAL pumps have "sealed in" lube oil.. The March pumps are available on E-bay and Amazon at pretty good prices..
Oct 29, 2005
2,366
It doesn't look like March pump. Perhaps its CAL. I'll get a picture this weekend.
Jun 25, 2012
942
hunter 356 Kemah,the Republic of Texas
will suck the chrome off a Buick!!
Yes I know I am bragging again!
I would highly suggest replacing with a little gaint pump. My original main a/c pump has seen 10 years of near continuous use and will suck the chrome off a Buick!!
2,366
Ok, I've checked. Mine is a CAL Pump PDS250-C. Nearest equivalent I think is the CAL MS-580(230VAC). I'll look into the LG and March. They're costly and Ihaven't seen a 230V 50Hz version. Will check Depco pump.
