This is a 2002 Hunter 270 (mostly identical to a 260) that I acquired two weeks ago. The boat had been winterized and on the hard for 10 months prior to our recent launch. In the process of flushing the antifreeze from the water system, I noticed what I first thought was a loose fitting on a seacock below the galley sink, starboard side. It's about six inches below the water line. On further examination (see pic attached) there is clearly a crack in the fitting just north of the stainless screw.
With the valve closed, no water is seeping in but with it open, a pretty severe leak. Here are my questions, and feel free to add whatever I am failing to consider in the solution:
1) What’s the best source for the part?
2) Given Mainsail’s wisdom and other assertions that Hunter executed a poor design here, is there an opportunity to improve this while fixing it?
3) Is there a safe and feasible way to do this in the water? (Plug the port from outside, heel the boat portside with weights and dock lines?)
Use of the galley sink is not a requirement, but since the boat has fresh bottom paint I was planning to leave her in the water (bubbling slip) this Winter, in hope of sailing as much as possible.
Appreciate any feedback on the way out of this one. I don’t want to leave it like this very long.
