New Backsplash
603
Catalina 30 Marathon, FL
Two years ago we re-did our interior in ultra leather. As all Catalina 30 owners know washing dishes splatters the back of the salon cushions with water. My wife decided this was a problem that needed fixing.
The new Catalinas solve the problem with a smoked Lexan backsplash. I priced the lexan and hardware with Catalina. After I started breathing again I made the mistake of thinking out loud "I wonder if we could do something with tile instead?"
Her eyes lit up "You mean like on the Gozzard?"
OK, so now I'm committed and I have to figure out how to do a tile backsplash. :doh:
I priced teak for the backsplash. I sat down and let the heart palpitations pass then decided on solid cherry instead. I found a custom tile place where I could get handmade dolphin tiles (my wife loves dolphins). I surrounded the dolphins with blue glass tiles that really light up when the sun hits them. The blue glass sparkles like sunlight off the water.
The quirkly little guy in the tile store suggested that since wood moves with the seasons I should bed the tile and fill the grout lines with latex calk. This sounded like a good idea.
I routed out the cherry so the tiles would sit flush. Oiled it with boiled linseed oil to bring out the figure, then top coated with several coats of a wipe on poly finish. Then I set the tile and let each side of the backsplash sit for a couple of days in the sun under our gazebo to "age" the wood to a deep, warm red/brown.
Next I "grouted" between the tiles with caulk. This is where I found out tile guy didn't know what he was talking about. Smoothing a grid of caulk is a real bear -- and the caulk kept shrinking because of the deep gaps between tiles. It took four applications at about two hours per application to do all the grout lines with anti-microbial caulk. I've since found an un-sanded flexible grout that would have made the job much easier. It would be fine because cherry really doesn't move that much with the seasons. A lesson learned.
It's been installed for a couple of weeks now. I'm happy with the result and the wife loves it (which is what really matters); and the beautifully grained cherry looks good from the other side as well. Next weekend I'll re-finish the rest of the galley trim; and I'm in the process of making a knife block that will mount to the backsplash by the rubber duck soap dispenser, which of course is a VERY salty accessory you only find on "serious" boats. ;)
Catalina 380 16 Rochester NY
Great job Jim;
Nice when a plan comes together in the end! From what little I can see of the boat, she looks like home!
Chris
jrowan
Mar 5, 2011
1,294
Looks good Jim,
I like it when sailors customize a boat & make it theirs with real improvements.
I wanted to install the lexan backsplash as well. So I guess it was real expensive, if your tile & wood fix was cheaper? Nice alternative. Cheers.
Feb 26, 2008
603
Chris,
she is our home on weekends so we've done a lot of small things to make her more comfortable. Thankfully I have a wife who enjoys being on the boat.
JRowan,
The backsplash from the 309 was around $200 if I remember correctly, but it was shorter than Kathy wanted. I think one from one of the bigger boats that would run the length of the counter was around double that.
I talked to Warren at Catalina. He was really helpful and would even do a custom length if I wanted. I can't say enough good things about my experiences dealing with the factory.
Jim
Nice work, looks great. One could also consider buying a piece of plastic from say Tap Plastics rather than CY and DIY.
Feb 26, 2008
603
Stu, thanks for the tip on Tap Plastics. I didn't know about these guys.
Bob S
Sep 27, 2007
1,808
Beneteau 393 New Bedford, MA
Jim,
Great job! I like the way it looks against the MKIII countertop.
108
Catalina 30 MKIII Beach Haven
Nobody liies a show off Jim. I know this will cost me more money. It's tough keeping up with the McGees!
jrowan
Mar 5, 2011
1,294
I imagine that a local glass shop could also cut & fabricate a piece of plexiglass or cut tempered glass to your specifications for less then $200 range. Just don't tell them the backsplash is for a boat, or they'll double the price!
Feb 26, 2008
603
Nobody likes a show off Jim. I know this will cost me more money. It's tough keeping up with the McGees!
I don't know Paul your slip neighbors are starting to talk about "that run down Catalina out on E dock" :naughty:
Put down the Pusser's, time for another boat project!
:D:D:D
