mike diehlman said:
Engine turns over nicely and has spark, but acts like it may be getting too much fuel. Some black soot/oil coming from exhaust but only at startup. I use about 75-80 pct throttle when starting. I have also experimented with less throttle with no improved results. Last year i had injectors rebuilt. New fuel /air filters. This year i cleaned the ground wire connection which helped a lot. Is it possible i may still have a weak ground connection?
I hate to leave an oil slick evertime i startup!
Hi Mike. I also have a 2QM15 from 1978. A couple of questions: does the starter crank the engine well? It will take a few seconds before there is enough heat built up to fire. Mine will crank for about 10-15 sec before it starts to fire, during that time fuel is being injected so when it does catch the exhaust is definitely black.
After clearing the initial fuel, I let it warm up at about 1000 or so rpm. There is no smoke at this point. I do get some white smoke when it's warmed up and underway but I know the compression is low-ish so there is unburned fuel in the exhaust.
We have a glow plug fitted but when I start the engine without it I get pretty much exactly the same result as you. When I use the glow plug, I energize the plug for 20 sec or so then crank with about 1/3 throttle and she fires almost immediately. The glow plug is essentially creating a hot environment for the atomized diesel, same thing that occurs after the engine cranks and builds heat through compression.
These older engines will never operate the same as their newer counterparts, so I just take comfort in the fact that she's 34 years old and will still cruise all day at 2200 rpm.
